Do I need a tune? + Other questions..
Old Nov 8, 2014 | 10:42 AM
ripley987's Avatar
ripley987
Question Do I need a tune? + Other questions..
Hey everyone,
So I have a 2006 350z with about 54k on the dash and 34k on the motor (replaced at 20k under warranty). So far I have added on the MREV2, 5/16th plenum spacer, an exoticspeed exhaust + y-pipe, and an AFe pro-dry drop in air filter.
My questions are the following:
-At this point do I need to get a tune to protect the engine?
-If I went and got an uprev tune would I see any noticeable gains?
-Is it worth the extra cost to get it tuned on a dyno vs. an e-tune?
-Are there any other mods I should consider getting before I get a tune? (I cannot put on high flow cats as no shop will touch them in VA due to emissions regulations).
Thanks for your help!!!
Old Nov 8, 2014 | 11:44 AM
.cakestar's Avatar
.cakestar
i honestly wouldnt bother with the tune until you touch your cats, either swapping them out for test pipes or hfcs. you will be a little lean right now but not that noticible
Old Nov 8, 2014 | 12:37 PM
The_Assassin's Avatar
The_Assassin
Originally Posted by ripley987
Hey everyone,
just do the swap to hfc yourself. It wasn't too hard. I did mine a couple months ago.
Old Nov 8, 2014 | 01:22 PM
Whiskers1996's Avatar
Whiskers1996
Some shops will install them, you just have to call around the local shops(I got when I had 2 bolts left).
I'm currently getting E-tuned and almost done. I have felt a great improvement so far.
Old Nov 8, 2014 | 03:55 PM
ripley987's Avatar
ripley987
Default HFCs
Alright, that makes sense. I can't install the HFCs myself because I live in an apartment that does not allow us to work on our cars in the lot (strictly enforced) and everyone I know lives in apartments as well.
If anyone knows of a shop in the D.C. or Charlottesville, VA area that will install a set of HFCs for a reasonable price let me know. Otherwise I'll just ask around.
Thanks!
Old Nov 15, 2014 | 04:37 AM
Awgd8's Avatar
Awgd8
When I uprev'ed (Etuned)my stock car, I could feel an improvement on throttle response ( I did my own throttle setting ) and increased some values on Torque management settings and it is really night and day difference for daily driving... BTW, I do not have a Z , but have the same VQ35HR engine 5 AT Infiniti EX35 AWD crossover. Almost 2 tons in weight.
The stock Cipher 0-60 run was just high 6.4x -6.7 secs. Uprev made it to 6.3 secs flat. Currently, after adding a bit of line pressure (Torque management) and replaced my spark plugs etc.. I managed to log a 6.16 secs (with spare tire, 1/4 fuel) 0-60 MPH. Granted, this is almost 4,000 pounds car! Car is almost at 70K miles now.
Old Nov 15, 2014 | 04:11 PM
seymore4's Avatar
seymore4
Professional
OP you don't "need" a tune, but it will make a big difference. Your car will be much more fun to drive.
Old Nov 15, 2014 | 07:43 PM
l2frankie's Avatar
l2frankie
currently running borla exhaust w/ magna flow x pipe, pop charger, mrev2 5/16 space, kintetix hfc with no tune. i just stay easy on the gas majority of the time. getting headers installed hopefully this tuesday coming up. was thinking about getting a tune after or try and have a shop custom make me a wider neck in the plenum with a 3.5" intake tube and 80 mm tb
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
