Clutch switch wiring to Haltech Pro PlugIn
Old May 22, 2016 | 05:39 AM
tcode's Avatar
tcode
Default Clutch switch wiring to Haltech Pro PlugIn
Does anyone using upper clutch switch with Haltech for flat or no-lift shift?
I have tapped blue-red wire from clutch switch to Haltech Digital Pulsed Input and asigned it to a clutch switch. Added light gauge with selected clutch switch channel. Getting absolutely no response when engage or disengage clutch switch.
Please help .
Old May 22, 2016 | 06:01 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Is the clutch switch providing +12v or does it just close a contact to ground?
Haltech is looking for 12v on DPI.
I also recall there being a ton of back and forth from haltech on how to install a clutch switch....as in they had it done one way and then another.
Old May 22, 2016 | 06:05 AM
tcode's Avatar
tcode
The clutch switch is providing +12V. But strangely, when disengaged, it still provide some voltage like 2V. I think that is a problem, Haltech DPI probably expect 0V for other state.
Old May 26, 2016 | 11:27 PM
tcode's Avatar
tcode
Figured out, problem solved.
Haltech DPI is pull up, I had to disconnect cruise control wiring from the upper clutch switch (not a big deal since Z isn't daily driven any more). So one pole of the switch is now wired to the ground and other to Haltech ECU DPI. Edge is set to rising.
Nick DeBerg
May 28, 2016 05:13 PM
ADVNTURR
May 23, 2016 03:00 PM
561350z
May 19, 2016 06:25 PM
ZFTW89
May 19, 2016 04:43 PM
