Bumping Timing in UpRev
Old Sep 17, 2016 | 10:36 PM
ZedFed's Avatar
ZedFed
Default Bumping Timing in UpRev
I'm self learning upRev and I simply want to add timing and some fuel for now so I will be busting number numbers myself. If anyone who knew me would know I really have no time for 2+ weeks waiting on a tune unless its for nitrous or FI, rather blow it up and do a swap if anything... Stock motor with an aftermarket air filter(Not the chrome autozone pipe). I so want a Kinetic intake I keep seeing, probably perfect for my nitrous kit i'm getting soon. Might sell off the ITS turbo kit too don't know yet.
Sometimes I miss just simiply turning the dizzy on my old 408w left or right, lock it and go lol
Old Sep 17, 2016 | 10:51 PM
ZedFed's Avatar
ZedFed
I found multiple sections for fuel and kinda stumped but imma focus on MAF and fuel compensation... don't quite know which one to use with the rest of em especially the K multiplier
Old Sep 18, 2016 | 02:48 AM
wannabuy350z's Avatar
wannabuy350z
post tune and log
Old Sep 18, 2016 | 06:00 PM
ZedFed's Avatar
ZedFed
Originally Posted by wannabuy350z
post tune and log
That's funny you said that... I literally JUST uploaded the tune and got back from doing a little log run. Runs like a freakin beast compared to stock. How do I post my log and the tune?
Old Sep 18, 2016 | 09:28 PM
ZedFed's Avatar
ZedFed
Thanks to wstar at the370z . com forum for the smooth throttle post. Works flawless and so much better. No lag. Add to "Electronic Throttle" Map. You can copy, Select all (CTRL+A), then paste (CTRL+V)
8064 8101 81A0 82CC 83F1 8507 8718 88FC 8AB5 8C41 8D4F 8DA3 8DF3 8E44 8E8F 8ED8
803E 80DE 8181 82B3 83DE 84F9 8712 88FC 8AB8 8C46 8D53 8DA6 8DF6 8E46 8E90 8ED8
8018 80BC 8162 829A 83CB 84EB 870C 88FC 8ABC 8C4B 8D57 8DAA 8DF9 8E48 8E92 8ED8
7FF2 8099 8142 8281 83B8 84DD 8706 88FC 8ABF 8C50 8D5B 8DAD 8DFC 8E4A 8E93 8ED8
7FCB 8076 8122 8267 83A4 84CE 8700 88FC 8AC3 8C55 8D60 8DB1 8DFF 8E4C 8E94 8ED8
7FA5 8053 8103 824E 8391 84C0 86FA 88FC 8AC7 8C59 8D64 8DB5 8E02 8E4E 8E95 8ED8
7F7F 8031 80E4 8235 837D 84B2 86F4 88FC 8ACA 8C5E 8D68 8DB8 8E05 8E50 8E96 8ED8
7F59 800E 80C5 821C 836A 84A3 86EE 88FC 8ACE 8C63 8D6C 8DBC 8E08 8E53 8E97 8ED8
7F33 7FEC 80A6 8203 8357 8495 86E8 88FC 8AD1 8C68 8D70 8DBF 8E0B 8E55 8E98 8ED8
7F0D 7FC9 8087 81EB 8344 8487 86E2 88FC 8AD5 8C6C 8D74 8DC3 8E0E 8E57 8E99 8ED8
7EE6 7FA6 8067 81D1 8330 8478 86DC 88FC 8AD8 8C71 8D78 8DC6 8E11 8E59 8E9A 8ED8
7EC0 7F83 8048 81B8 831D 846A 86D6 88FC 8ADC 8C76 8D7C 8DCA 8E13 8E5B 8E9C 8ED8
7E9A 7F60 8029 819F 8309 845C 86D0 88FC 8AE0 8C7B 8D80 8DCE 8E16 8E5D 8E9D 8ED8
7E64 7F2F 7FFC 817C 82EE 8448 86C8 88FC 8AE5 8C82 8D86 8DD3 8E1B 8E60 8E9E 8ED8
7D47 7E2C 7F13 80C1 825D 83DD 869B 88FC 8AFF 8CA5 8DA5 8DED 8E30 8E6F 8EA7 8ED8
From this point forward, these are my tunes. Nothing aggressive as I'm learning. The car seems much more aggressive and actually got rid of my warm bog I used to have all the time too. I will upload my log soon once I figure how. These are also complete maps, no partial.
<b>Injector Latency</b>
msec at 14v Battery = 21
msec change per volt = 5A
<b>Calculated Load</b>
0000
6E53
742B
7F48
7E30
827C
8ECE
8D78
8D06
92A6
9590
9F36
A2D9
A531
A2DB
9EC4
<b>Map 1 Fuel Compensation - Still reading a bit more on this</b>
73 73 73 72 70 70 71 71 71 6F 6F 6F 6F 6D 6D 6D
76 76 77 77 75 74 78 7A 78 78 78 78 72 72 72 72
77 77 75 74 75 74 74 77 75 74 74 74 73 73 73 73
77 77 75 75 73 74 73 74 76 76 77 76 76 76 76 76
7B 7B 78 74 74 74 75 79 75 79 78 7A 76 76 76 76
78 78 77 74 74 75 76 78 76 76 79 78 77 76 76 76
77 77 76 72 72 74 76 77 78 77 7A 78 78 77 77 77
78 78 77 74 74 73 75 7A 7A 77 77 77 77 77 77 77
76 75 73 73 73 74 77 77 76 77 77 77 77 77 77 77
76 76 76 74 74 75 77 77 77 77 77 77 77 77 77 77
74 74 74 74 74 76 76 77 77 77 78 79 7A 7A 7A 7A
73 73 73 73 74 75 75 76 76 77 79 7A 79 79 79 79
74 74 74 74 76 76 77 77 77 79 79 7B 7B 7B 7B 7B
75 75 75 75 75 76 76 77 77 78 79 7A 7B 7B 7B 7B
72 72 72 72 75 76 77 7A 78 7A 7A 7A 7A 7A 7A 7A
72 72 72 72 75 76 76 78 77 7A 7A 7A 7A 7A 7A 7A
<b>Ignition Timing - +3 Degrees on 93oct</b> ... A little bold yes but might drop 1 degree but pulls so darn hard. and so folgers crystals woke up.
46 46 4A 45 43 40 3C 38 37 36 36 38 38 39 39 39
44 44 44 42 41 3E 3E 3C 37 38 39 3A 3B 3C 3C 3C
42 42 44 44 44 44 43 41 3F 3C 3A 3B 3C 3E 3E 3E
41 41 42 42 42 42 41 40 3E 3D 3C 3E 3F 40 40 40
40 40 40 40 40 41 41 40 3F 3F 3D 3F 40 41 41 41
3F 3F 40 41 40 41 40 42 42 41 3F 40 42 43 43 43
3E 3E 3E 3F 3F 40 40 41 41 41 40 43 44 46 46 46
40 40 40 41 41 41 42 42 43 43 43 43 45 46 46 46
43 43 43 43 43 43 43 44 44 44 45 44 45 46 46 46
45 45 45 45 45 44 44 45 46 45 44 43 45 46 46 46
43 43 43 43 43 43 42 42 42 41 42 41 42 43 43 43
44 44 44 44 43 42 41 41 41 41 41 42 43 44 44 44
45 45 45 45 43 41 40 41 40 3F 40 3F 3F 40 40 40
43 43 43 43 42 42 41 40 3F 3E 40 3F 3E 3F 3F 3F
42 42 42 42 42 42 42 42 41 40 41 3F 3E 3F 3F 40
42 42 42 42 42 42 42 41 42 41 42 40 41 42 42 42
<b>ETC Control - YOU WILL LOSE CRUISE CONTROL - SETTING IS BEST FOR MANUAL CARS</b>
OFF
From what I read on about the ETC long story short is that it keeps the ECU from trying to mathematically compensate and make adjustments. Straight volt reading from close | Open | Close.
I will post the log once I figure out how. It was only a 15 minute run from home to the gas station a few miles up and freeway back. May do a video as well.
Old Sep 18, 2016 | 09:49 PM
ZedFed's Avatar
ZedFed
Here is my log file. It's attached
File Type: csv
Old Sep 18, 2016 | 10:00 PM
ZedFed's Avatar
ZedFed
post tune and log
I posted it above...
Old Sep 19, 2016 | 09:46 AM
venture210's Avatar
venture210
You might want to log your AFR's also
Old Sep 20, 2016 | 12:43 AM
ZedFed's Avatar
ZedFed
Currently no access to a wideband at the moment. It's on my list though as I will need it.
Bak3rme
Oct 10, 2016 07:50 PM
OdesiTT
Tuning
Sep 22, 2016 08:42 AM
scooterdog1040
Sep 16, 2016 06:44 AM
