350z platinum pro plug in rear aux connector?
Old Aug 15, 2019 | 08:11 AM
specialist's Avatar
specialist
Default 350z platinum pro plug in rear aux connector?
I just bought new ecu for z33 platinum pro plug in. Moving from the red box. I wanted to know if someone can confirm the following below
Sensors I would like to hook up to the rear aux connector
-Boost solenoid
- Air temp sensor
-Dual wideband Controller
Haltech Air Temp sensor (2 pins)
A) Ground (PIN # 4)
B) Signal (PIN # 3)
Haltech Boost Control Solenoid 3 Port (2 pins)
Power (+12V Switched) (PIN # 16)
Haltech Output (PIN # 13)
-Haltech Dual wideband Controller
Blue output2 afr (pin 11)
white output1afr (pin 10)
TT03Z
Tuning
Mar 6, 2017 03:36 PM
