DEFI, SPEC Clutch, Walboro Fuel Pumps and More..
Vendor - Former Vendor
DEFI BF SERIES AMBER GAUGES
BF AMBER Boost - $239.00 shipped
BF AMBER EGT - $259.00 shipped
BF AMBER Oil Pressure - $259.00 shipped
BF AMBER Fuel Pressure - $259.00 shipped
BF AMBER Water Temp - $199.99 shipped
BF AMBRE Oil Temp - $199.99 shipped
Control Unit Ver II - $99.99 shipped
*** Extra 3% off for purchase of 3 or more gauges *********
Shipping will be via UPS ground. To upgrade to 2nd day air, please add $10.
Any combination of three or more gauges, we will throw in
1. Free Defi Sticker
3. Extra 3 % off for purchase of 3 or more gauges*******
DEFI BF Series White Gauge Set (60mm)
- Boost Gauge
- EGT or Oil Pressure or Fuel Pressure
- Water Temp or Oil Temp
- Control Unit Version II
- Free Oil pressure adaptor to engine block
- Free Defi Sticker
$ 739 shipped
DEFI V2 Link Gauge Set (60 mm or 52 mm) / (Black Or White)
- Boost Gauge
- Free Defi Sticker
$ 639 shipped
DEFI D Gauge Series, 52mm black or white
- Boost Gauge
- Temperature Gauge or Air Fuel Ratio Gauge
- Oil Pressure or Fuel Pressure or EGT Gauge
- Free adaptor for oil pressure sensor for easy install
- Free Defi Sticker
$ 379 shipped
DEFI Link Display Set
- Any pressure set including EGT
- Any temperature sensor set
- Free Oil Pressure adaptor to engine block
- Free Defi Sticker
$ 629 shipped
DEFI VSD Concept (Head Up Display)
- Free Defi Sticker
$ 629 shipped
Other DEFI Accessories
- 6 Feet Meter Cable - $17
- Fitting Kit - $15
- Single Meter Visor - $19
- Indicator II - $80
Spec clutches are some of the highest quality on the market -- with a specific stage for any level of performance in your 350z. We reccomend replacing or resurfacing your flyhwheel with any of these clutches.
Clutch Kit For 03-04 350Z
Stage 1:
$ 479.00
High clamp pressure plate, steel-backed woven organic disk, bearings and tool.
Torque Capacity: 430 lb/ft.
Stage 2:
$ 579.00
Torque Capacity: 485 lb/ft.
Stage 3:
$589.00
Great Street/Strip clutch. High-clamp pressure plate, 3-piece disc with carbon or ceramic material, bearings and a tool.
Torque Capacity: 560lb/ft
Stage 4:
$589.00
High-clamp pressure plate, 2-piece rigid disc, bearings and a tool. Available in 3 or 6 wing design for serious road racing and drag racing.
Torque Capacity: 560lb/ft.
Stage 5:
$719.00
High-clamp load pressure plate, iron disc, bearings and a tool.
Torque Capacity: 720 lb/ft.
Walbro 255LPH High Flow Fuel Pump 350Z
$89.00
If forced induction or ultra high performance NA use is in your Z or G's future, then an upgraded fuel pump should be at the top of your list of ancillary parts needed to safely accomplish your HP goals. rated at 255 liters per hour (stock pump is 90 liters per hour)
All the order will need to be taken by phone or e-mail only.
Don't see what you looking for? Please don't be hesitate to give us a call.
TEL: 718 -358-6102
EMAIL: sales@ravspec.com
AIM: ravspec02
- Boost Gauge
- Free Defi Sticker
$ 739 shipped
- Boost Gauge
- Free Defi Sticker
$ 639 shipped
- Boost Gauge
- Free Defi Sticker
$ 379 shipped
- Free Defi Sticker
$ 629 shipped
- Free Defi Sticker
$ 629 shipped
- Fitting Kit - $15
Stage 1:
$ 479.00
Stage 2:
$ 579.00
Stage 3:
$589.00
Stage 4:
$589.00
Stage 5:
$719.00
$89.00
TEL: 718 -358-6102
AIM: ravspec02
