07 350z tune up
what kind of service does the z need after 30,000 miles i have a new tranny and i just replaced oil now im wondering is it better to buy our own fluids or take it to dealer to get it all flushed out and have them use oem products
'07 350z 30k Severe Service
Inspect
Brakes and Traction Control (S) Notes
Perform at mileage interval or every 6 months whichever occurs first. Inspect: Brake Pads, Rotors, Drums and Linings.
Cruise Control Vacuum Hose (S) Notes
Perform at mileage interval or every 12 months whichever occurs first.
Evaporative Emissions Hose (E) Notes
Perform at mileage interval or every 24 months whichever occurs first.
Exhaust System (S) Notes
Fluid - A/T (S) Notes
Perform at mileage interval or every 12 months whichever occurs first. If towing a trailer, using a car-top carrier, or driving on rough or muddy roads, replace the fluid/oil every 30,000 miles or 24 months whichever comes first.
Fluid - Differential (S) Notes
Fluid - M/T (S) Notes
Fuel Supply Line (S) Notes
Steering and Suspension (S) Notes
Perform at mileage interval or every 6 months whichever occurs first. Inspect: Axle and Suspension Parts, Front Suspension Ball Joints, Steering Gear and Linkage, Steering Linkage Ball Joints.
Replace
Air Filter Element (E) Notes
Perform at mileage interval or every 24 months whichever occurs first. When driving for prolonged periods in dusty conditions, check/replace the filter more frequently.
Cabin Air Filter (S) Notes
Perform at mileage interval or every 12 months whichever occurs first. When driving for prolonged periods in dusty conditions, check/replace the filter more frequently.
Engine Oil (B) Notes
Perform at mileage interval or every 3 months whichever occurs first.
Oil Filter, Engine (B) Notes
(S) = Service Warranty Requirement
(E) = Emission Warranty Requirement
(B) = Both Service and Emission Warranty Requirement
Under normal conditions there is no reason to worry about fluids (other than oil) until 60k.
Inspect
Replace
in other words, not much :P
check your fluids, you know what your brakes/tires are like, you know how your clutch feels, check the air filter, there is no fuel filter to replace, change the oil and call it a day
im surprised how little maintenance the Z needs, there's really not much
this is the first car i owned that you don't need to replace a fuel filter... i was a bit confused about that. everything ive read said you dont need to replace the fuel filter, and i asked a parts guy at nissan and he told me the same thing. i think it's built into something that may need servicing eventually, but not until after 60k
Guys, did anyone look at the manual???
How about diferential fluid replacement, coolant replacement, manual transmission oil replacement? check the color of you brake fluid (should be clear or light brown, not black) check belts and replace if cracked - check interior part of tires (uneven tire wear) lubricate locks and hinges...
Recommended Services: 30,000 Miles or 24 Months
Replace
Replace engine oil and filter • • •
Lubricate all locks/hinges •
Lubricate propeller shaft (4WD) 1 • • •
Road test vehicle
Replace automatic transmission/CVT fluid •
Replace differential oil (limited-slip, conventional) 2 •
Replace engine air filter • • •
Replace engine coolant/flush system •
Replace engine drive belts •
Replace free-running hub grease 3 • • •
Replace limited-slip differential oil • •
Replace manual transmission oil •
Replace radiator cap •
Replace wiper blades •
Optional: flush automatic transmission (flush with ATF) •
Inspect Premium Schedule 1 Schedule 2
Air conditioning system
All lights •
Automatic transmission/CVT fluid • •
Axle & suspension parts • • •
Battery fluid level/terminals
Brake lines & cables • • •
Brake fluid level
Brake pads, rotors, drums & linings • • •
Charging/Starting system
Clutch fluid
Cruise control vacuum hoses • • •
CVT fluid (Murano) • •
Differential oil 2,8 • •
Drive shaft boots 6 • • •
Engine coolant level/top-off
Engine drive belts 9 • •
Exhaust system • • •
Free-running hub grease
Front suspension ball joints • • •
Front wheel bearing grease (2WD only) • • •
Fuel lines/connections • • •
Fuel tank vapor vent system hoses • • •
Headlights/adjust if necessary •
Horn operation
Limited-slip differential oil
Manual transmission oil 8 • •
Power steering fluid/top-off
Propeller shaft 2 • • •
Radiator hoses
Shock absorbers/struts
Steering gear and linkage • • •
Steering linkage ball joints • • •
Tires/adjust air pressure
Transmission fluid/oil
Washer fluid level/top-off
Wiper blades
1 Propeller shaft should be re-greased after being immersed in water.
2 350Z, Frontier, Murano AWD, Pathfinder, Armada, Titan, Xterra.
3 4WD versions of Frontier, Xterra.
4 Frontier, Pathfinder, Xterra.
5 Standard equipment on Altima, Maxima, Murano, Armada LE, Quest SE, and Titan Crew Cab LE, SE. Optional accessory on all other models.
6 All models except 2WD versions of Frontier, Pathfinder, Titan, Xterra.
7 Optional equipment on Frontier, Xterra.
8 Replace (not just inspect) oil if towing a trailer, using a camper or a car-top carrier, or driving on rough or muddy roads.
9 Frontier, Pathfinder, Armada, Titan, Xterra.
Equipment varies by model. Perform only those operations that apply to your vehicle.
from this place: http://www.nissanusa.com/owning/vehi...intenance.html
Replace
Road test vehicle
All lights •
Brake fluid level
Clutch fluid
Horn operation
Radiator hoses
Wiper blades
hardkicks
Sep 20, 2015 12:28 PM
07350z, 350z, automatic, change, coolant, cost, flush, interval, maintanance, oil, recommended, scheduled, transmission, tune, vq35hr
