Lightweight Flywheel
Old Feb 26, 2008 | 01:31 PM
rkemp1's Avatar
rkemp1
Originally Posted by Justin@IOS
Well, I've had one slave cylinder fail to where the car was inoperable and my second one is making scary noises at idle after the last track day. This is all on the stock clutch, flywheel, etc... If someone managed to do the same with an aftermarket clutch, it wouldn't surprise me at all.
I'm just hoping this old design slave will last me until the flywheels are released... might as well get the "free install" while you can
And on top of that, I'm really hoping the new design fixes everything. If I'm going to go through slave cylinders every track day or so, it's going to either get REAL old and/or I'm going to get REALLY efficient at dropping the transmission.
lets hope it doesnt come to that
Old Feb 26, 2008 | 02:04 PM
hawaiianZ's Avatar
hawaiianZ
just make sure to change out your crankshaft/flywheel bolts. i would change it out(new), whenever you upgrade to light flywheel/stronger holding clutch. loctite etc..... you dont want to shear those bad boys off while driving to work. had to repair a few of my friends nissans. it wasnt a 07 though. a light weight flywheel is a good upgrade, you have to get used to it. i always kept hitting redline, it comes up way quicker then u think.
Old Feb 26, 2008 | 03:19 PM
tribal_visionz's Avatar
tribal_visionz
yay for mods be created for the HR!
Old Feb 26, 2008 | 03:31 PM
Sensi09's Avatar
Sensi09
Works Concepts
It's probably dependent on the dealer, but others have tried to get aftermarket clutches installed while getting the recall, but were refused.
So other than saving money on labor, is there any advantage to getting both the flywheel and clutch at the same time. Other than the obvious advantages of the aftermarket clutch itself of course.
Old Feb 26, 2008 | 03:54 PM
rkemp1's Avatar
rkemp1
someone correct me if Im wrong, but I was always told that If you were replacing the clutch and not the flywheel that its recommended that you at least have the flywheel resurfaced so that it mates up better with the friction disc of the clutch assembly.
Old Feb 26, 2008 | 11:20 PM
hawaiianZ's Avatar
hawaiianZ
if re installing old flywheel, then yes go ahead and resurface it. if not you can end up with premature wear on clutch, or uneven wear.
Old Feb 28, 2008 | 07:29 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
Wow really? That sucks. Most of the dealers around here are normally pretty cool about that stuff. No real advantage to getting both at the same time, other than the savings in labor if you're eventually planning to upgrade the clutch as well.
Old Mar 4, 2008 | 07:51 PM
fwdracer1838's Avatar
fwdracer1838
any updates on a flywheel?
Old Mar 9, 2008 | 02:37 PM
BenchTT's Avatar
BenchTT
updates bump
Old Mar 13, 2008 | 01:21 PM
BenchTT's Avatar
BenchTT
Just ordered the JWT fly for the 07+. They are shipping tomorrow.
Old Mar 13, 2008 | 01:35 PM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
I have a few on order through JWT as well and were told they were "right around the corner".
I can't wait to get mine in and get the updated slave cylinder as well.
Old Mar 13, 2008 | 04:34 PM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
They were right, I just got the tracking number for our order so it looks like I'll have my flywheel on Monday.
Old Mar 13, 2008 | 05:48 PM
Sensi09's Avatar
Sensi09
Works Concepts
What's the weight of the JWT flywheel? Same weight as older versions?
Old Mar 13, 2008 | 06:14 PM
BenchTT's Avatar
BenchTT
14lbs
Old Mar 13, 2008 | 06:23 PM
warmmilk's Avatar
warmmilk
whats the weight of the stock flywheel?
Old Mar 13, 2008 | 06:57 PM
BenchTT's Avatar
BenchTT
Not 100% sure of the HR but <07 was 23. Guessing around the same.
Old Mar 13, 2008 | 07:23 PM
singh's Avatar
singh
_______________
When somebody gets a lightened flywheel installed, post up some before/after dyno graphs. Kill the speculation, and lets see what kind of power this lightened flywheel can make.
Old Mar 13, 2008 | 07:25 PM
  #38
Sensi09's Avatar
Sensi09
Works Concepts
Lightweight flywheels do not produce any power. Therefore, dyno numbers will not change.
Old Mar 13, 2008 | 07:28 PM
  #39
singh's Avatar
singh
_______________
I don't understand. How can this be beneficial then?
Old Mar 13, 2008 | 07:30 PM
  #40
toy4two's Avatar
toy4two
is the 07 flywheel dual mass like the 03's? If so expect a noisy driveline if you put in a solid one like I did.
