downshifted into a wrong gear!!!!!!!! (in my HR)
Old Mar 17, 2008 | 07:37 PM
itsjiggajames's Avatar
itsjiggajames
Originally Posted by GrayG35
if anything ends up being wrong (not likely) you have warranty lol
I don't think a warranty covers money shifts.
Old Mar 17, 2008 | 07:46 PM
LeMans 05's Avatar
LeMans 05
Nope. At least not w/ my boss' mis-shift. The car's computer recorded the overrev, and Honda's warranty didn't cover it. Cost him $3k.
Old Mar 17, 2008 | 07:47 PM
350Zimo's Avatar
350Zimo
Originally Posted by Peak350
The reason the rods would crack is because it isn't a smooth rev to redline and its not a loaded rev. The rods are in tension instead of compression and the crankshaft is loaded backwards. This throws balance off and the rods can get tweaked pretty bad. I'd be more worried about the vavletrain typically, but since no-one really knows the strength of the rods in the HR its something to keep in mind.
How do you find out if they have been cracked. the engine runs smoothly, no knocking, no hesitation, . i know you are not saying that my motor has cracked anything whatever it is, but how does it feel? can you determine that just from driving or it has to be inspected
Old Mar 17, 2008 | 07:48 PM
350Zimo's Avatar
350Zimo
350Zimo's Avatar
350Zimo
Old Mar 17, 2008 | 07:50 PM
350Zimo's Avatar
350Zimo
sorry about that my comp is freaking out
Old Mar 18, 2008 | 07:25 AM
Peak350's Avatar
Peak350
Thats a question I can't really answer.
I think its pretty much like if you cook a rod it turns color and you have to drop the oil pan to see....you probably would have to inspect them each to know for sure.
On the BMW motors I'm (more so at least) familiar with the bottom ends will take 8-9k with 0 issues even in a mechanical over-rev. They are very stout, but they can also handle about 600 whp (from a 2.8/3.0L) with a thick MLS gasket, so the rods are a bit stronger than ours.
Thats why I say it could have happened. Its one of those things that 3 or 4 people on this forum can actually answer, and I'm not one of them.
Old Mar 18, 2008 | 08:47 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
You'd honestly have to inspect everything, to know for sure.
FWIW, I over-revved my track car a few years back (SR20 motor) and it just spit up most of the rocker arms and dislodged a few things in the head. It was just a simple, put them all back in place and reshim everything job though. The bottom end was fine afterwards (crank, rods, rod bearings, main bearings, etc...) but I had to tear down everything to check. Wasn't very fun, but I built it up stronger in the process, so it was kinda worth it.
Old Mar 18, 2008 | 09:03 AM
Peak350's Avatar
Peak350
Lucky you didn't shear the rockers apart. The SR over-rev's I've seen were ugly.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
