bad hesitation after downshift
Old Apr 25, 2009 | 02:12 PM
militia's Avatar
militia
Default bad hesitation after downshift
anybody had similar problems?
scenario: in 6th gear about 65mph, pushed the clutch in, bought the RPMs up to downshift in 3rd for a hard pass and my car hesitated and stumbled violently.
2007 350z 36,060 miles
Old Apr 25, 2009 | 04:42 PM
Probably need a new fuel pump.
Old Apr 25, 2009 | 08:44 PM
hellsoldiers08's Avatar
hellsoldiers08
well is it a auto or standard?? from what you said i would think it standard. it shouldnt really have that pause if it standard and if it auto then it kinda alright. Either way like the guy said it could your fuel pump could be going out or something good thing you got warrenty and should take it to the dealer or tell the dealer to note it in your record.
Old Apr 26, 2009 | 10:39 AM
kyx4n's Avatar
kyx4n
lol.. he said "pushed in clutch"
im quite sure the auto doesnt have a clutch..
and +1 on taking it to dealer/shop
Old Apr 27, 2009 | 02:55 PM
NY350zG's Avatar
NY350zG
I've caught my car doing that about twice.. But I've always thought that it was driver error because I am not used to this N/A motor.. I've owned turbo cars my whole life.
I say go out and try it again.. and again and see if it does it EVERYTIME... or just see if your doing something wrong...
BTW... Do you have any mods? and if so... What are they?
If it does it EVERYTIME or even 4 out of 6 times I say bring it to the Dealership, but that's always my last resort.. Hope everything works out
Old Apr 27, 2009 | 04:39 PM
Phenom's Avatar
Phenom
Toasty
better revmatch?
Old Apr 27, 2009 | 04:51 PM
warmmilk's Avatar
warmmilk
it could be your tcs kicking in. in cooler weather the z has enough power to spin the tires a little when going to 3rd at 65, try it with tcs off (carefull not to spin out) see if it still happens
Old Apr 27, 2009 | 04:53 PM
warmmilk's Avatar
warmmilk
what would you do different on a turbo car that would cause hesitation on an na car?
i drive both (my sister has an sti), the only thing that causes hesitation for me is if i left tcs on...
Old Apr 27, 2009 | 07:30 PM
NY350zG's Avatar
NY350zG
Downshifting on a turbo usually puts you right into boost... On an N/A they each have there "Powerbands" and its usually at a HIGHER rpm then a turbo.
And warmmilk... Its HIS issue your Z may not have this issue.
Old Apr 28, 2009 | 05:33 AM
militia's Avatar
militia
I thought It was me at first, but this has happened 3 times in all now. Ive tried multiple times and the problem is intermittent. I have some mods but the only "performance" and I really would'nt even call it a performace mod is K&N drop-ins and an EVO2 exhaust.
I am keeping a watch on it, I really dont want to have to go to the dealer.
Originally Posted by Phenom
better revmatch?
I thought that at first also
base model, no TCS
Thanks for the replies everyone, like I said the problem has been intermittent and I just wanted to see if anybody else was having this issue.
It has not acted up since, and I still have not decided if I should take it to the dealer (keep in mind my warranty is up) or just wait until the problem gets worse.
Old May 25, 2009 | 07:07 PM
WV350z's Avatar
WV350z
I've had my HR for about 35-40 days and have had it happen to be a handle of times during a downshift or such...I just have a JIC Y pipe back exhaust..I juft figured it was because I needed a tune probably?hmm
Old Jun 1, 2009 | 08:04 AM
Frosty87's Avatar
Frosty87
shut tcs off thats what i sounds like to me
Old Jun 1, 2009 | 09:03 AM
warmmilk's Avatar
warmmilk
sorry for the way late response, but it could be the k&n drop ins. if the oil off the filter got onto the maf's, it could be that its messing up the reading. i friend of mine had the same issue on his supra...
try getting some maf cleaner, clean your maf's, and replace the k&n's with some oem filters and see if you still have the problem
Old Jun 1, 2009 | 09:05 AM
warmmilk's Avatar
warmmilk
i have a cat back exhaust (motordyne y pipe and fujitsubo exhaust) and i've never had this issue. i doubt its cause of lack of tune...
Old Jun 1, 2009 | 03:07 PM
NISMO_558's Avatar
NISMO_558
it's a base model, theres no TCS
Old Jun 8, 2009 | 08:53 AM
Frosty87's Avatar
Frosty87
are you rev matching when downshifting or just killing your trans and slaming it into the lower gear I've seen this done 1 too many times and sooner or later something will give ... this could be causing the hesitation
Old Jun 8, 2009 | 09:09 AM
Tac-M's Avatar
Tac-M
was the car cold ? or just barely warmed-up ? like 5 min or so ?
Old Jun 8, 2009 | 03:25 PM
quidproquo's Avatar
quidproquo
Need a Tune!!!
I have experienced the same intermitent hesitation issue... Only happened about 3 or 4 times under heavy acceleration in second or third gear. Car was driving temperature, and did not follow a downshift (in my example). I did notice the SLIP light on my dash flashing in tune with the hesitation. Typically turning off the TCS stops the hesitation. Not sure if they are related, it just seems to solve it in my case.
I'd go to the dealer, but causing the hesitation to occur on command is next to impossible, so I'm hoping for a TSB at some point if enough people complain about it.
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
