Why does my car make so litle power???
Old Jun 2, 2009 | 07:30 AM
s14_2Nv's Avatar
s14_2Nv
^^ Agreed. Did you get a baseline done before putting on the osiris and tuning it?
Old Jun 2, 2009 | 07:55 AM
B5I8's Avatar
B5I8
This is a before and after tune.
Old Jun 2, 2009 | 09:49 AM
Smackin's Avatar
Smackin
+8 hp on a tune...Is pretty kick ***. I would love to get +8 from a tune
Old Jun 2, 2009 | 10:49 AM
B5I8's Avatar
B5I8
Yeah, I'm content with my numbers and now I'm moving on to suspension. Thanks for the replies.
Old Jun 2, 2009 | 02:52 PM
3fittyBiH's Avatar
3fittyBiH
maybe temp had something to do with it?
Old Jun 2, 2009 | 03:31 PM
Manjot's Avatar
Manjot
But the real question still remains unanswered. How come you're making less power even though you have more mods?
Old Jun 2, 2009 | 04:29 PM
Ataru074's Avatar
Ataru074
depends on the baseline, depends how "safe" the tune is, depends on the temperature/humidity of that day, depends on the quality of the fuel he has in the tank...
if he was around 260 on the baseline he's doing good.
IMHO.
Old Jun 2, 2009 | 05:11 PM
Manjot's Avatar
Manjot
Thanks
Old Jun 2, 2009 | 05:19 PM
T_K's Avatar
T_K
Aside from the mods listed, everything else is OEM?
TK
Old Jun 2, 2009 | 06:49 PM
kramykram's Avatar
kramykram
try the dyno again and hold your jaw to the left a bit see what that does for ya.
Old Jun 2, 2009 | 08:16 PM
Cali-Darkness's Avatar
Cali-Darkness
Were all the mods done the same day/visit?
If no, In what order were they installed?
Old Jun 2, 2009 | 09:51 PM
Peak350's Avatar
Peak350
What was the weather like for his pull vs your pull.
I've found at the drag strip that our cars are a LOT slower (less power) above about 75 degrees. If I remember reading right, our ECU only pulls timing, doesn't add, so if its hot enough that your engine pulled timing, that could explain it.
Old Jun 2, 2009 | 09:56 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
If your dad bought it for you you make less power.
Old Jun 2, 2009 | 10:10 PM
jace350z's Avatar
jace350z
I topped out at 265 with true duals and intake and a mild tune.
Old Jun 2, 2009 | 10:47 PM
A.H's Avatar
A.H
Old Jun 2, 2009 | 11:19 PM
67ZNISMO's Avatar
67ZNISMO
Even though they were dyno'd on different days, their are multiple issues that can occur when tuning on different days such as temperature, humidity, types of gas used, old/new gas. Temperature on parts also play a big role as different coating's can retain or release heat differently causing your WHP to drop or rise. It is possible you have a leak... or the parts aren't installed correctly.
Other questions: What was your Air Fuel? Do you have CEL on? How many times did they dyno your car - Its possible your car was really hot.
Old Jun 3, 2009 | 07:14 AM
B5I8's Avatar
B5I8
You guys are so funny that I'm not even going to bother.
Old Jun 3, 2009 | 09:30 AM
  #38
Cali-Darkness
My Questions were serious ones. I have an idea of what happened but Im sure things will get sorted out.
Old Jun 3, 2009 | 10:22 AM
  #39
Manjot's Avatar
Manjot
+1. Just ignore dave chappell.
Old Jun 3, 2009 | 11:02 AM
  #40
B5I8's Avatar
B5I8
No. I did the Injen Intakes, AAM HFC's, and an Ark exhaust first. Then I had them pull the Ark exhaust and install a Bassani and they did the headers as well (about a month later). The tune was done last at least a week or so after the Bassani and headers.
Yes, it was probably a lot cooler when that other car was dyno'ed. My car was done on a hotter day.
