HR - represent !
Old Jun 29, 2009 | 06:36 PM
  #121
Tac-M's Avatar
Tac-M
^ we all need $... do the work yourself and there is nothing wrong with used parts....
and only get what you really like, never settle for the second choice.
Old Jun 29, 2009 | 06:53 PM
  #122
Peak350's Avatar
Peak350
What clutch/flywheel are you running? Stock?
Old Jun 29, 2009 | 06:58 PM
  #123
Tac-M's Avatar
Tac-M
JWT fly - stock clutch .
clutch fluid got way to hot on the last track day... so i need to work on that.
Old Jun 29, 2009 | 07:41 PM
  #124
Peak350's Avatar
Peak350
Have you ever had grinding on startup (starter gear not engaging).
Half the reason I want to switch is that I think the JWT has an aluminum gear (I need to look) but regardless mine is all messed up...FML.
  #125
rps13drift's Avatar
rps13drift
What fluid do you plan on changing it with? Oh and awesome thread! Very inspirational for me for I plan on doing track days with my Z in the near future.
Old Jun 29, 2009 | 07:47 PM
  #126
Peak350's Avatar
Peak350
Well, I don't think the clutch fluid really recirculates, so a DOT6 would be a smart idea. Motul R600 I think...
Old Jun 30, 2009 | 12:06 AM
  #127
Tac-M's Avatar
Tac-M
yes i do ! it is not that bad , and i learned how to deal with it quickly. but man, i had a starter replaced and it did not fix the problem, so it's definitely a flywheel issue .
Old Jun 30, 2009 | 03:36 PM
  #128
Peak350's Avatar
Peak350
Well, my flywheel gear teeth are rounded off on that edge, and the starter gear teeth were worn from it.
**** it, stock flywheel is $100 at a junkyard, I'm going to buy a stock clutch kit, a new slave (to be safe) that flywheel, and call it a day. This way I don't have to worry about CSC failure, I don't get grinding, or chatter, or have to worry about if I wanted to sell my car, and its easier to launch at the drag strip with the OEM.
I can't lose on this one.
Old Jun 30, 2009 | 04:30 PM
  #129
Ataru074's Avatar
Ataru074
you might want to check the exedy flywheel...
the clutch (stage 1) could work with the stock flywheel... to me sounds like the exedy flywheel could work with the stock clutch.
Old Jun 30, 2009 | 04:54 PM
  #130
musubi's Avatar
musubi
I hear ya
Thinkin the same thing today.
Old Jun 30, 2009 | 05:28 PM
  #131
Peak350's Avatar
Peak350
Ehh, looks like $600-800 for the flywheel...vs $100 for an OEM.
While its probably cool, its not different enough from OEM to matter...
Old Oct 21, 2009 | 02:52 PM
  #132
DaProdigy's Avatar
DaProdigy
nice pics/vids Bruddah! HR just keeps gettin better and better... btw whose silver amuse is that? that ish is rice!
Old Oct 26, 2009 | 02:27 PM
  #133
Tac-M's Avatar
Tac-M
hr has been asleep for a wile..... but it's not dead ! so very fun things will happen next year ! ))) dare i say more WHP ?
here she is ... hibernating ... dreaming bout new volks ! lol
edit ... and her lol
Old Oct 29, 2009 | 10:09 AM
  #134
thinking's Avatar
thinking
Was your cage built to any specs (SCCA, NASA, etc.)?
Old Oct 29, 2009 | 10:13 AM
  #135
Tac-M's Avatar
Tac-M
^ yes . i am not an expert, but the shop that did is. http://www.robinsonracing.net/
Old Oct 30, 2009 | 05:13 AM
  #136
thinking's Avatar
thinking
Do you have any additional photos of where the cage is welded near the seats? I can not see the plate that the tubes are welded to in the photo with the door sill in it.
Also, are you able to replace any of the plastic trim behind the seats in order to be able to use the cubby storage again?
Sorry for all the questions.
Old Oct 31, 2009 | 09:35 AM
  #137
Tac-M's Avatar
Tac-M
here ya go.... and there is no plastic back there... but it was my choice.
Old Oct 31, 2009 | 11:56 AM
  #138
thinking's Avatar
thinking
Thanks
Old Dec 10, 2009 | 06:40 AM
  #139
Tac-M's Avatar
Tac-M
here is the latest....
<img src="http://i289.photobucket.com/albums/ll208/djtacm/_Proc_Flat_8bit_NI2_USwide_sRGB.jpg">
Old Dec 10, 2009 | 08:47 AM
  #140
krnzzang84's Avatar
krnzzang84
damn looks tight
