Tomei Camshaft for VQ35HR??
Old Jun 16, 2009 | 01:34 PM
biggersNISMO's Avatar
biggersNISMO
ha ha, ^^ what he said... and for the Revshift intake lol
Old Jun 16, 2009 | 02:15 PM
A.H's Avatar
A.H
Well the Revshift Intake Manifold, I already promised I would guinea pig that, that's coming along nicely. Now with these cams....i want them, don't get me wrong, I love NA motors, but it's just so expensive. Might as well do a build while the engine is torn down. This, plus the fact that I'm pretty broke makes the cams most likely not going to happen(unless I can find really cheap labor without my car blowing up which isn't likely)
Old Jun 16, 2009 | 02:48 PM
0jiggy0's Avatar
0jiggy0
I completely forgot about Revshift lmfao
Old Jun 16, 2009 | 03:45 PM
MDHRZ's Avatar
MDHRZ
Yea might as well put that money towards the ATS clutch. That plus the Greddy TT Tuner Kit and a few other goodies. That's my plan
Old Jun 17, 2009 | 09:13 AM
JK_HRZ's Avatar
JK_HRZ
I wish i could read japanese.
So which camset would give the most power for a full bolt-on NA HR along with reliability? Which lift, etc?
Anyone have a guess in power gains with these cams and a decent tune?
I'll be glad to test these cams out, just tell me where to buy them without having to translate japanese.
~ J
Old Jun 17, 2009 | 09:16 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you don't need to read japanese, I posted a translated link as well
there is no "best", there are different specs, for different uses. Worth reading up on lift and duration in general senses of the words, and then taking that info, applying it to your intended use and overall plan, and making your selection
Old Jun 17, 2009 | 10:50 AM
JK_HRZ's Avatar
JK_HRZ
Sounds like a plan, was planning on reading up when i got home from work anyways
Old Jun 17, 2009 | 11:13 AM
JK_HRZ's Avatar
JK_HRZ
Just read the page on your site Z1. Do you or any other vendors out there sell aftermarket valve springs suitable for the 272 and/or the 280 lift's?
Also let me get this straight, the 264 lift's do not need aftermarket valve springs and the oem ones can be used. What are the specs for the oem cam's for VQ35HR's?
Also during installation, whether it be the 264, 272, or 280 lift's, you may or may not need to replace your lifters and the only way to know is during installation.
Old Jun 17, 2009 | 11:25 AM
warmmilk's Avatar
warmmilk
the 2xx number is the duration, not lift
the 10.x and 11.x are the lift values
Old Jun 17, 2009 | 11:40 AM
JK_HRZ's Avatar
JK_HRZ
okay.
The higher the lift, the greater amount of air that can be traveled through the intake / exhaust valves. Which is why valve springs are needed for higher durations (272 & 280) because of the higher lift and increased amount of traveling air.
This is like high school all over again
Old Jun 17, 2009 | 11:50 AM
warmmilk's Avatar
warmmilk
yes, better valve springs are mainly needed cause of the higher lift, i don't know of anyone that makes them for the hr (doesn't mean nobody does, i just don't know of anybody)
Old Jun 17, 2009 | 04:16 PM
0jiggy0's Avatar
0jiggy0
Found this on another site.
CVTC: Intake and Exhaust
Intake__Lift: 10.5mm
Exhaust_Lift: 10.5mm
Intake__Duration: 248º
Exhaust_Duration: 248º
Intake_Opens: 2º BTDC
Intake_Closes: 66º ABDC
Exhaust_Opens: 68º BBDC
Exhaust_Closes: 0º BTDC
Overlap: 2º
The intake cam has been advanced by 4º and the exhaust cam has been advanced by 2º.
The spark plug lised in the ESM is the Denso FXE22HR11
Same smaller valves as on the 2007 Altima.
Stiffer valve springs than the 'revup' engine. Strongest springs to date on any known production VQ engine. They might be the same as the Nismo springs.
113-127lbs @ 26.2mm (vs. 98-110lbs @26.2mm revup)
Edit: Also this nice pdf from JWT
http://www.jimwolftechnology.com/wol...INCL_REVUP.pdf
Old Jun 18, 2009 | 11:25 AM
biggersNISMO
now that i look at my budget, i might be willing to be the "lab rat" for this product....
Old Jun 18, 2009 | 11:52 AM
JK_HRZ's Avatar
JK_HRZ
So these are the specs for the oem cam's in HR's?
Old Jun 18, 2009 | 11:54 AM
0jiggy0's Avatar
0jiggy0
Yessir.
Old Jun 18, 2009 | 12:08 PM
JK_HRZ's Avatar
JK_HRZ
Okay, so valve springs need to be upgraded because of the higher lift of aftermarket cams.
The tomei 264 Duration and 10.8mm lift cams will work without having aftermarket valve springs.
Okay, now what about the 272 Duration and 10.8mm lift cams? They have more duration, but they have the same lift. So couldn't I use the 272 / 10.8 cams without having to change oem valve springs?
Old Jun 18, 2009 | 12:41 PM
warmmilk's Avatar
warmmilk
if you actaully go through with doing this, you should discuss this with you engine builder and go with his recommendations.
that being said, if i were doing this, i'd do the valvesprings anyway since i have the head opened up already...
Old Jun 18, 2009 | 12:49 PM
  #38
DressUpBoutique's Avatar
DressUpBoutique
Vendor - Former Vendor
I agree with warmmilk while your head is open might as well do as much as you can to keep from reopening it
Old Jun 18, 2009 | 12:52 PM
  #39
JK_HRZ's Avatar
JK_HRZ
I agree completely, but is there anyone that sells aftermarket valve springs for the HR?
Old Jun 18, 2009 | 01:22 PM
  #40
biggersNISMO
GT Motorsports does i think
http://www.gtmotorsports.com/search....=search&page=1
