HR Clutch to handle 600+ WHP/TRQ
Old Jan 16, 2011 | 07:35 PM
neverenough's Avatar
neverenough
I have the os giken twin and the upgraded slave. Built 3.8 hr GTM TT making 700whp 700wtq . took it to the track and it held fine on a 10.60 pass and daily abuse.
Old Jan 16, 2011 | 07:40 PM
neverenough
def. need the upgraded slave . Mine stock slave only lasted a few hundred miles with the twin disk.
Old Jan 17, 2011 | 04:30 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the OS is a very popular setup for the HR
if you need one, let us know
Old Jan 17, 2011 | 10:11 AM
xJC350x's Avatar
xJC350x
Thanks guys, I have the OS Giken coming in and should have it tomorrow along with the CSC. Hey neverenough I have an off topic question for you, what kind of fuel system setup are you running. The very last thing I need to complete my setup is a good furl return/ pump setup. Trying to stay in the budget yet gotta pay to play so need something quality. What did you do? Anybody else have a say? It is so hard to find compatible and readily available parts for the HR. thanks for everyone"s help.
Old Jan 17, 2011 | 10:43 AM
ace32x's Avatar
ace32x
did the gtm stage 0 return with mine with a sard regulator
Old Jan 17, 2011 | 04:00 PM
neverenough
Its the twin in tank kit. GTM put it all together with their fuel rails and regulator.
Old Jan 19, 2011 | 06:54 AM
xJC350x's Avatar
xJC350x
Ok Thanks. I'll see what I come up with.
Old Feb 21, 2011 | 11:53 AM
DaveSB's Avatar
DaveSB
Originally Posted by Z1 Performance
no, they are not the same
the CSC, by it's design and nature, necessitates a different presure plate as the contact area differs substantially between a DE throw out bearing and HR. Not sure if flywheels differ, have never taken the time to notice
Flywheels are different. The HR flywheel and clutch is the same as the 370z. The DE flywheel has a different shaped timing ring and it's in a different location then the HR/370z.
The clutch in the 2005.5-up HR/370z is 240mm and the DE 2003-2004 used a non self-adjusting 250mm pressure plate. 2005-2005.5 used a self-adjusting 250mm pressure plate made by LUK. This occasionally varied, but generally is true. Also, the HR/370z pressure plate uses a rounded diaphragm finger for the CSC where both DE style pressure plates had flat fingers for the rounded DE bearing.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
