Problem with Thermostat?
Old Oct 27, 2011 | 04:41 AM
jerseystyle's Avatar
jerseystyle
Default Problem with Thermostat?
So I am having some issues. Yesterday I had the heater going in my car but it just wouldn't heat up. When I checked my temp gauge is was way up close to the H. Is the thermostat not working properly? Coolant levels are fine and the engine doesn't seem to be over heating. I did a search but couldn't find anyone with the same symptoms. Thanks!
Old Oct 27, 2011 | 04:59 AM
Spork's Avatar
Spork
Sounds about right.
Old Oct 27, 2011 | 01:24 PM
SE5spd's Avatar
SE5spd
do either of you guys know where to get a NISMO Thermostat for an HR?
Old Nov 1, 2011 | 06:24 AM
Rob@Z1's Avatar
Rob@Z1
Have you opened up the cooling system lately? Its unlikely to be the thermostat, the OE unit RARELY fails. More than likely its air still trapped in the system, since the Heater Core is the high point in the system.
Old Nov 1, 2011 | 08:38 AM
Italianjoe1's Avatar
Italianjoe1
Sounds like a failed water pump or air in the system as mentioned. Even if the t-stat is stuck closed the bypass will still pump water through the heater.
Old Nov 1, 2011 | 02:06 PM
jerseystyle
Yeah, I think it was air. Seems to be okay now. I guess when I drained the system last I did a half assed job.
Uriyo_
Sep 8, 2021 08:46 AM
