N/A Built HR discussion
Old Feb 2, 2012 | 07:47 PM
  #41
ace32x's Avatar
ace32x
Originally Posted by johnwigs
problem with BC stroker kit is you have to loose oil squirters...
here is a video of "stroked" 3.7L (not a VHR)with big cams...
<iframe width="560" height="315" src="http://www.youtube.com/embed/1L4U3coPR8U" frameborder="0" allowfullscreen></iframe>
i have a BC 4.07L stroker and we maintained my oil squirters they had just enough clearance, not sure who told you loose them...
Old Feb 2, 2012 | 07:57 PM
  #42
johnwigs's Avatar
johnwigs
really? maybe the added deck height helped... the DE stroker kit was a nightmare!!! I still wouldn't use BC because of brand loyalty, was any other clearancing needed?
Old Feb 2, 2012 | 08:15 PM
  #43
ace32x's Avatar
ace32x
no sir everything fit in perfect, me and my builder were very pleased with the motor assembly went smooth
Old Feb 2, 2012 | 08:21 PM
  #44
johnwigs's Avatar
johnwigs
hmmm, that is good! I'm glad BC updated their kit... a little pricey but nissan stroker kit can only get up to 3.8 with GTR crank and then need some slight modification to make work... I'm working on 3.7 stroker kit that will be pretty cheap compared to other kits as long as your not doing over 8k RPMs!!!
Old Feb 2, 2012 | 08:32 PM
  #45
johnwigs's Avatar
johnwigs
teaser:
Old Feb 2, 2012 | 08:35 PM
  #46
ace32x's Avatar
ace32x
price wasnt to bad either, i payed $4800 and got the crank rods pistons and arp bolts for the connecting rods
Old Feb 2, 2012 | 08:39 PM
  #47
johnwigs's Avatar
johnwigs
thats a pretty reasonable price
Old Feb 2, 2012 | 08:52 PM
  #48
ace32x's Avatar
ace32x
yea it wasnt to bad for what i got i thought
Old Feb 2, 2012 | 08:55 PM
  #49
johnwigs's Avatar
johnwigs
660whp isn't too bad either!!! is that on pump? or C16
Old Feb 2, 2012 | 09:56 PM
  #50
ace32x's Avatar
ace32x
pump with water/meth
itl be over 700 hopefully tomorrow. was having an issue with my 8lb wastegate springs and my boost controller. wasnt keeping the gates shut underload and was only seeing 18 psi of boost. swapped the springs out to 20 psi and they held fine, we ran it to 28 psi but a poor piping fitment on the lower pipe from the passenger turbo to the IC (GTM gives u like a 5" coupler for that one) expanded like a balloon and the t clap put a gash in it. modifying the piping so it will take a popper sized coupler tomorrow and putting it back on the dyno and seeing what itl do with the extra boost
Old Feb 3, 2012 | 07:13 AM
  #51
str8dum1's Avatar
str8dum1
still have squirters on my DE as well. You only lost squirters with their 88mm stroker kit which was discontinued years ago.
Old Feb 3, 2012 | 06:10 PM
  #52
johnwigs's Avatar
johnwigs
ok so there is (or was) more than 1 kit available... I had a bad experience (oil squirter plug backed out and boom!) and I won't go down that road again!!! plus if the factory puts in oil squirters then there must be a reason that the pistons need that extra cooling
Old Aug 18, 2012 | 06:00 AM
  #53
rich2342's Avatar
rich2342
Awesome thread. too bad nobody has any built HR numbers and specs. Wish more would consider n/a
Old Aug 20, 2012 | 02:36 AM
  #54
SoCal07HR's Avatar
SoCal07HR
Yeah I always thought this was a great thread. I still plan on building my HR N/A one day but thats going to be on the back burner as I'm working on a cage and full race prep first. Goal is going to be light weight so no 70 pound turbo or supercharger kit for me. I'm planing on rods, hi comp pistons, cams and valve springs, longtube headers, injectors, and tuned on 110 race fuel.
I wish there was more info out there on NA built HR's. I really don't want to be the first. Stroker might be nice too but I think i can reach my goal of about 350 horsepower without one.
Old Aug 20, 2012 | 08:35 AM
  #55
ace32x's Avatar
ace32x
id like to hope you could, SG made like 370 na with a DE. on stock displacement.
get a 4.2 high comp stroker some c10 jwt cams and get an itb setup and im sure you could break the 400 mark with 110
Old Aug 20, 2012 | 11:04 AM
  #56
KingBaby's Avatar
KingBaby
Hardest Setting
SG also did lots of tuning in COLD weather...
Old Aug 20, 2012 | 11:33 AM
  #57
SE5spd's Avatar
SE5spd
SoCal I thought you sold your Z for a c5?
Old Aug 20, 2012 | 11:40 AM
  #58
ace32x's Avatar
ace32x
thats why i said stroker itb's big cams and 110 would yield 400 on an HR, would be more than 400 im sure in the same weather.
Old Aug 23, 2012 | 08:04 PM
  #59
SoCal07HR's Avatar
SoCal07HR
That was the plan but I just didn't have the heart to sell her. I've got it mostly stripped out and it'll be going in for the cage in a week or two. I'll have pics and such when there's progress. After my chassis and suspension is rebuilt I'll get to work on the engine.
Old Aug 25, 2012 | 06:18 AM
  #60
Jaxter's Avatar
Jaxter
Subscribed.
I am also interested in a mild street N/A build. Johnwigs posts are some of my favorites. I'd like to put together an all-Nissan VQ37HR. Im not a mechanic whatsoever, but I'm game to get JTran Studios to throw in a Crank, Rod, Piston, Cam Combo. I'd be stoked to get a 350 WHP Daily driver with an 8K redline.
