Need advice plz
Old Mar 8, 2012 | 05:09 PM
itzseEk's Avatar
itzseEk
Default Need advice plz
im lookin to upgrade my clutch to at least a stage 2 on my 08 nismo any 1 have a specific suggestion..... thanksssss
Old Mar 8, 2012 | 10:38 PM
Above: A clutch that looks like the OEM clutch will perform similar to the OEM clutch. Manufactures generally refer to this as Stage #1. You can also call this clutch street friendly.
Above: Misinformed members often buy a clutch with a clamping capacity that exceeds their needs. Thinking is that if it can hold say, 400 pounds of torque, than it must be "better." The result will often be an aggressive clutch that is a pain in *** to operate for a daily driver.
NOTE: If you are shopping for a flywheel and clutch, I recommend that you buy a flywheel and clutch from the same manufacture. They are designed and tested to work together.
Old Mar 10, 2012 | 05:56 PM
jerseystyle's Avatar
jerseystyle
Also, if you get anything other then a stock clutch you will also need a heavy duty CSC.
Old Mar 11, 2012 | 05:59 PM
itzseEk's Avatar
itzseEk
saroya i have read up on the subject just couldn't make up my mind u fruit cake if i ever wanna know sum thing retarded like the difference between an intake ill b sure to ask u for sum help........ lol jersey style and david thanks once again u guys always know wassup lol
Old Mar 12, 2012 | 02:40 AM
sijia10358's Avatar
sijia10358
I believe ACT is bang for the buck.
Old Mar 12, 2012 | 05:04 AM
jerseystyle
Some good info HERE.
When I replace my clutch, I'm gonna go with the Southbend stage 2 clutch/flywheel, HD CSC, and the Wilwood master cylinder. Check out http://www.zspeedperformance.com/main.sc
norrix420
350Z Roadster
May 23, 2022 05:11 PM
liqalu04
Jan 2, 2022 12:58 PM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
