N/A Power of a HR Z
No need for $1100 polished headers, get the normal bare metal ones for $900 and save yourself $200 nobody is gonna see them anyway.
Get a used exhaust , $1200 for an exhaust is too much , for me at least lol. Got my nismo s-tune exhaust for $400 in mint condition.
Intakes , you can find injen or stillen long tube cold air intakes for a lot less than $500. Or just spend $100 for k&n drop ins.
Osiris tuner costs $700 but that's assuming one can tune it himself. Better off paying a good tuner $400-$500 for a good tune without you having to buy the cable, unless of course you want to.
Yeah as for installing parts i never let anyone do things on my car, the only thing i had a shop do was set the final drive gear after i took everything apart and brought it to them, ive never done that before nor do i wanna learn lol. $150 was not bad at all considering how much people pay to get their gears installed.
I didn't add labor because it is different for everyones skill set... Bolt-ons most people can install themselves, cams is a little bit harder and time consuming without proper tools...
Headers, without having custom ones made no one really makes one that works well since Header design is determined from cam profile and head flow characteristics, the LTHs that are on the market are designed to mate up to the stock location of the cat flange to the Y-pipe, and they are WAY to long! even 700ci engines don't have primarys that long, diameter is what is important and the collector is secondary of importance (sounds right...) SFR headers use a Burns Stainless collector (the best!!!) and are available in 1 5/8 and 1 3/4 primaries, it is IMO the best (I am not at all afiliated with SFR) header, other than a custom one
Intake, If you are comparing NISMO intake to K&N drop in filters then you need not apply to the NA world
Clutch, I am a JWT fan so $800 will do you good... I have drivin the carbonetic triple and love it!!! but $3200 is a bit much for a clutch
exhaust, Stillen is crap! they haven't made anything good (except for custom stuff they do a pretty good job on) since the Z32 days... there also wasn't any competition
I am now back on the SR20 bus, My NA SR20 made nearly 180whp (that is alot for 2liters) now my blue bird engine is near 280whp and I hate it! yes it is faster in a straight line, but since I go to palamar Mt all the time, the response and noise it used to make is not there! So I am going back to NA to make 220WHP NA!!! Yup 2.2L stroked Sentra!!!
The gains seen from the PPE headers is from removing the cats... maybe a 5hp gain is actually from the header... If you want "long-tube headers" at least the PPEs quality looks pretty good and have an expansion chamber in after the collector, which is good
I guess it's that "no stone left unturned" ...
Also the exhaust note is pure sex, too raw for some...
As stated above I've been telling folks test pipes first then if you want more even though it's minimal LTHs!
so would you say that stillen shorties coupled with test pipes produce the same gain as going longtube headers?
Everytime someone mentions STILLIN I vomit in my mouth... I have no idea why people are still buying Stealin's crap... good marketing I guess?
My suggestion on the Long tube option is to make sure you have a quality exhaust behind it that has an "X" pipe or combined chamber... if you leave it true dual, you just sound like an angry chewbacca!!!
1 5/8 might be ok for the stock 238 cam on the DE, but 1 3/4 is pretty standard. The 248 cam on the RevUp and HR I'd say 1 3/4 is the minimum size, with a lean towards 1 7/8.
The LTH available aren't too long, if they are too long, they are much closer to the right length than any set of shorty headers, regardless of whatever brand expensive collector you put on it. All data out there converges on a primary length of ~30in, a little less for higher rpm and a little more for less rpm. The calculations for the shortest designs point at 24-26in, and that's for something around 7000rpm.
370z with 3.7 HR is what is raced in the GS class (there also is an altima coupe, but I don't do engines for that team so they are slow), there is no restrictions other than using "factory" components (Cams are a NISMO N10 prototype), and Bosch control pieces, the car has not finished consistantly high enough to start restricting the car, most of the funding has been put into the Australian V8 Supercar series, that NISSAN has dumped $millions! and team budgets here for Grand Am CTSCC, are much smaller, and engines costing $25,000 for long blocks, it gets expensive!
K&N and short ram type intakes gain = 0. Unless you are dumb and blind and missed the countless dynos of them, just ignore anyone who states otherwise.
Requesting HP figures for mods is very inconsistent. It all depends on the Dyno used. My Z dynos 285rwhp on a Mustang dyno @ 100F+ temps. I could easily result in 300-310rwhp at a different tuner shop that has a Dynojet in the same conditions. Also if I were to dyno at say 50F temps, I may run higher numbers as well, same with at different elevation levels.
All you need to know for a point of reference is the HR Z with full boltons will run relatively more power than a DE/RevUp in comparison IF you dynoed both on the same machine @ the same conditions.
. im in tampa btw
. anyone on here have them? I
