HR Z - Bolt-on options?
Old Feb 28, 2014 | 02:04 PM
  #41
travlee's Avatar
travlee
Master
Yeah but I wouldn't do it for a daily car
Old Feb 28, 2014 | 07:20 PM
  #42
RacingBlack350Z's Avatar
RacingBlack350Z
Originally Posted by travlee9374
mine doesnt say it anywhere on it... but l really dont care.. not like you really see it anywhere. but on another note, my muffler cracked mostly from dragging speed bumps in my apts, i emailed tony and even though i told him i drug it and thinned it out, he said he would replace it at no cost to me under warranty..., genuine stand up guy
I wanted it just for authenticity in case I ever sold the car or the exhaust, god forbid haha but yes tony has always been really helpful and knowledgeable
Old Mar 1, 2014 | 06:48 AM
  #43
radiocrash's Avatar
radiocrash
I was gonna do 4.08 gears but I wouldn't want to for a DD
Old Mar 1, 2014 | 07:05 AM
  #44
The_Assassin's Avatar
The_Assassin
I use my car daily with 4.08 gears and it's no big deal. I don't even notice any change in gas usage.
Old Mar 1, 2014 | 08:58 AM
  #45
secwind's Avatar
secwind
Only inconvenience I had with 4.08 is the higher RPM at cruising speed. It sits at around 3000 RPM for 70mph. What's so bad about it for DD? All the extra drone from test pipe/ exhaust is much worse for DD.
Old Mar 2, 2014 | 10:53 PM
  #46
PeterSellers's Avatar
PeterSellers
Originally Posted by secwind
You will feel more of a difference with 4.083 alone than any of the bolt on mentioned here.
You might "feel" more of a difference but as far as acceleration goes, gears will only help you in first gear. Any gear past that and it is a wash between 4.08's and the stock gearing.
Old Mar 3, 2014 | 04:52 AM
  #47
Lonestarr350's Avatar
Lonestarr350
So I'm guessing the 4.08 gears isn't work it ???
Old Mar 3, 2014 | 05:22 AM
  #48
The_Assassin
Yes it is worth it. I don't know where that guy above got his info from. It makes no sense while it would only improve first gear. It increases acceleration in every gear by around 15% if I remember correct. Research for yourself and don't listen to false info. Read through that thread.
https://my350z.com/forum/engine-and-...installed.html
Old Mar 3, 2014 | 07:23 AM
  #49
secwind's Avatar
secwind
This is not true. Final drive affects all your gears. You actually gave up top speed for acceleration.
As far as DD with 4.08 goes, it's much easier to start in 2nd in traffic. You don't have to slip the clutch nearly as much. On highway, you never have to downshift to 5th to pass. You're already sitting around 3000RPM in 6th gear at cruising speed, just have to put the foot down and go
edit: I have PPE longtube header, full exhaust, intake, uprev tuned. If I have to keep just one power mod, it will be 4.083. It did more than all those plumbing combined.
Old Mar 3, 2014 | 07:48 AM
  #50
BigBlue's Avatar
BigBlue
I'm not so sure about that. My 3.9's made 4th-6th "wake up" let alone the lower gears; 3rd is nasty. Makes sense as with the new fd gears even say at 80 mph you are reving a few hundred rpms higher than stock. I definitely noticed a difference in the positive column in all gears as soon as I had the 3.9's installed.
1st gear "only" would be a waste of time and $$; like mentioned above, "all" gears are effected; ask most any of the guys on the site who have gone 3.9/4.08's and ask if they did or didn't get a big smile on their faces as they were trying out the new setup for the first time.
Old Mar 3, 2014 | 09:52 PM
  #51
Lonestarr350
Appriciate that info guys! So I will be looking into the 4.08 gears forsure now!
Old Mar 4, 2014 | 03:04 PM
  #52
PeterSellers
Let me clarify: all gears are indeed affected by getting 4.08s, but do not forget that you are also shortening the length of each gear in the process! That is an important consideration which often gets forgotten when changing out your final drive.
Because each gear is now shorter, that means you have to shift to the next gear earlier which has a higher effective ratio than the gear before it, whereas the stock geared car can stay in the lower gear longer and benefit from the shorter effective ratio of that lower gear. If you are racing from a roll, it ends up being a wash because the short geared car will be faster at some points (until it has to shift into a higher gear), at which point the stock geared car will pull a little more. It kind of goes back and forth.
With that said, there is no doubt in my mind that 4.08s "feel" faster and make the car a lot more fun to drive. Part of that feeling faster is because the gears are shorter and you have to shift more often. But don't kid yourself...from a roll, they are not actually faster than a stock geared car. You can't get around the laws of physics.
Old Mar 4, 2014 | 03:21 PM
  #53
BigBlue's Avatar
BigBlue
^stock gearing gets the mpg up to sell cars. Most any car or truck could be tuned/geared for better performance, whp, tq from the factory, but mpg on the little window sticker could be a turn off to potential buyers who want better mpg. I doubt that the Z33 would have a fd gearing of 3.5 "if" it didn't hurt gas mileage otherwise. The tuning would also be different, giving more whp/tq, but more performance drops that magical mpg # and sales are affected. I say go ahead with the more agressive fd.
Old Mar 5, 2014 | 08:24 AM
  #54
PeterSellers
I agree with this for the most part, although shorter gearing is also worse on the freeway simply because you are cruising at a higher rpm, which negatively impacts drivability/comfort level.
If the Z was my weekend car and I was staying N/A, I would definitely get the gears. Since the Z was my daily I thought the stock gearing was a better choice. That's a personal opinion though.
Still, I wanted to clear up the misconception about 4.08s being "15% faster in all gears" because that implies that the car will always accelerate faster than a stock geared car, when that is quite far from the truth.
Old Mar 5, 2014 | 11:47 AM
  #55
Lonestarr350
My z is DD .. I rarely drive on the highway so it sounds like it wouldn't be a bad idea to get them.
Old Mar 5, 2014 | 12:20 PM
  #56
doshoru's Avatar
doshoru
I think part of it was cost cutting on nissan's behalf when moving from the DE to the rev-up, and then finally the HR. The FD stayed the same while the max RPMs climbed. If the original 350Z was released with a 7500rpm redline, there's a very good chance it would have had a higher FD. An HR reaches the same or higher speeds in 3rd gear (105ish) than many other sporty cars with way more power -- e9x m3? 105ish. c5 z06? 103ish.
Usually the car that makes less power has the shorter gears to make up for it.
Old Mar 6, 2014 | 08:57 AM
  #57
Glenn350zHR's Avatar
Glenn350zHR
Believe me! I WILL get that tdx2! .. In your opinion are the stillen long tubes better than the jwt dual pop charger?
intakes are not worth the expense on the HR. I dynoed both stock and stillens with no gains. Just save the money and invest it into the tune. I run stock boxes with k@N filters but your jwts are probably fine too since you already have them. only bolt on mods worth the money doing with a stock motor and not going forced induction is addressing the exhaust cats back. Then get the car tuned and call it a day. You will be in the 290-300whp range like many before you.
I am against the gearing change but thats just preference. what the car really needs even at this power level is a real limited slip diff like a Quaife.
Old Mar 11, 2014 | 03:40 PM
  #58
AURMEND's Avatar
AURMEND
304hp! https://i.imgur.com/LD76IlB.jpg
Mods:
Injen Long Tube Intakes
CNT Resonated Test pipes
Invidia Gemini Exhaust
93 Octane btw
How is my car compared to others.
Old Mar 11, 2014 | 04:25 PM
  #59
The_Assassin
Mods:
93 Octane btw
Much faster. Stock my numbers were 273 whp and 244 wtq. You got 304 whp and 272 wtq. Is that with a tune ?
Old Mar 11, 2014 | 04:42 PM
  #60
travlee's Avatar
travlee
Master
he is on a dynojet.... every dyno is going to be a little different based on how it is calibrated. i hit 286 on a mustang which are supposedly 7-10% low.
