number on lower intake manifold
Old Jan 29, 2016 | 05:22 PM
AznAliaz's Avatar
AznAliaz
Default number on lower intake manifold
hey guys, I was looking into porting and polishing the lower intake manifold and was looking for used ones on ebay. I see there are a few different casting numbers ranging from 1-4 before the JK4 then LH. Was just wondering if those numbers has any significance in determining if it will fit in my 07? Also, do you guys think im wasting my time or should it be a easy and cheap "upgrade". Any input will be appreciated.
Old Jan 30, 2016 | 05:18 AM
cincysilvias14's Avatar
cincysilvias14
why would you polish a plastic intake manifold? the hr's head flows perfectly good.
Old Jan 30, 2016 | 06:34 AM
AznAliaz's Avatar
AznAliaz
The lower i/m is aluminum on the HR, only the upper i/m is plastic. z1 sells them ported and polished for $350 with a core return. I figure I save myself a little money and have a little project to past some time in this cold weather.
Old Jan 30, 2016 | 10:05 PM
John_B's Avatar
John_B
There shouldn't be any other variation of IM for the HR, as long it is for the 07-08 350z it should fit. If you have other supporting mods (Full Bolt On) and tune, this would be a good upgrade to pick up a few more hp. You have to tune the car to get the best out of the ported manifolds. I would port match and polish both Upper/lower manifolds and get the PCV elimination kit (breather). If you don't eliminate the crankcase ventilation hose, your going to have oil/carbon build up in those ported manifold.
Old Jan 31, 2016 | 01:43 PM
AznAliaz's Avatar
AznAliaz
So im assuming the 1-4 is just like a production time stamp then, thats good to know! I have intakes/HFC/XYZ/Nismo exhaust with no tune yet. But im planning to uprev it sometime soon, hopefully them tax refunds come in the clutch. Do you think a catch can while keeping the pcv there work with the oil coating on the LIM after the port and polish?
Old Feb 1, 2016 | 06:15 AM
John_B's Avatar
John_B
Contact Z1Motorsport and get Uprev Standard from them. Jon P. is their tuner and he'll take care of you. Best tech support IMO, he just finished tuning mine with E85 (via e-tuned).
I don't have a catch can yet. but, I went with EPS PCV elimination.
Basically removing the the line going back in the IM and replace them with breathers. Add this group in FB and message them for one. Here's a photo with my 3" intake setup.
https://www.facebook.com/epstuningtx/
Antlaw
Apr 8, 2016 08:43 PM
SxExCx
Jan 30, 2016 11:30 AM
sales@aamcomp
Jan 29, 2016 06:55 PM
Detailed Image
Cleaning & Detailing
Jan 29, 2016 04:37 AM
Audionoob
Jan 25, 2016 08:21 AM
