Water/meth injection
Old Jun 5, 2017 | 09:44 AM
Frankd1210's Avatar
Frankd1210
Default Water/meth injection
Anyone know if water/meth injection system is a reliable system as far as failsafe.
Old Jun 5, 2017 | 03:47 PM
Conway_160's Avatar
Conway_160
If you buy all the bells and whistles then yes it can be a decent failsafe. But DON"T rely on this to run crazy power numbers.
Old Jun 5, 2017 | 04:10 PM
Frankd1210's Avatar
Frankd1210
With what I'm doing I don't need any more hp
Old Jun 9, 2017 | 09:09 AM
BakaN20's Avatar
BakaN20
Are you planning to run w/m continuous, activate after certain parameters are met, ie rpm/wot/psi, or triggered when a certain condition occurs, ie lean?
What kind of setup are you going to be running? From what a couple tuners told me, you tune for the gas you are running then add w/m as an extra layer of safety, don't tune to the w/m.
There are a lot of things that can go wrong, clogged nozzle, using the wrong mixture, etc. Thats where the bells and whistles come in, such as units that monitor flow and premixed methanol. So you don't want to rely soley on w/m.
For my setup. when I am N/A, i have a switch to activate my w/m that will run anytime my rpm passes 3000, regardless of throttle position. This runs at 100ml/min
When I run nitrous, my w/m activates the same time and under the same parameters as the nitrous. This runs at 350ml/min. I can deactivate my other w/m nozzle or run it at the same time.
Old Jun 9, 2017 | 09:30 AM
Frankd1210's Avatar
Frankd1210
Default Water/meth
no I just want to use it when I race
