p2a03
My car has started throwing the p2a03 code.
I have checked for exhaust leaks but no visible ones. My upstream wires are intact as well.
I do get an occasional p0300 random miss code sometimes as well as a p0420(Catless)
The car is running good and getting 19.2mpg av29 mph
I did have TBs removed for cleaning and DID NOT replace gaskets, and used my hand to TQ down. The intake resonator tube was missing a hose clamp that I replaced yesterday.
any thoughts? could it be a vacuum leak?
I'm going to double check and see if the exhaust manifold needs to be tightened. I'm in school, so it may take longer.
Edit Update: Had my dad stick a leaf blower in the tailpipe and I sprayed water+soap around the manifold. bubbles formed around the header to cat section. No gasket in either of the collectors! going to put some in tomorrow. Hopefully, this is the solution.
Zomgfast123
Jan 20, 2010 05:47 PM
