Injectors
Old Sep 9, 2018 | 02:27 PM
CptWiggles's Avatar
CptWiggles
Default Injectors
I'm replacing my knock sensor and trying to take out the fuel rail and injectors to get to it. Everything's unbolted and disconnected and I'm pulling on the rails and not getting anywhere, is there something I'm missing or do I need to use a lot of force?
Also since I'm in their would there being any benefit to getting larger injectors? I don't plan on ever going fi or really making over 350 whp.
Old Sep 9, 2018 | 05:48 PM
Conway_160's Avatar
Conway_160
No need to go bigger, the stock ones will be sufficient, sorry cant help with knock sensor i have a DE.
Old Sep 9, 2018 | 05:58 PM
bealljk's Avatar
bealljk
Can you take the the intake manifold off the engine with the fuel rail still attached to it?
no point in going with larger injectors...
Old Sep 9, 2018 | 06:01 PM
CptWiggles's Avatar
CptWiggles
I got it all off thanks, I had to use a pry bar and a completely unreasonable amount of force, things almost went South quickly because the o ring and other little plastic piece on a few of the injectors popped off. Luckily those valves we're closed so I could fish them out no problem. Definitely used up all my luck with that one.
Old Sep 10, 2018 | 09:20 AM
ajpasa's Avatar
ajpasa
Man, thanks for this post. I have a DE, but my best guess is that both Knock Sensor changes look alike; and I will do mine in a 2 of weeks.
I've seen one Youtube video where the guy keeps the injector in place, and wobbles the intake out of there through the fuel rails. I thought about doing that, since it's probably a good measure to change the o-rings if we remove the injectors...
And now that you mention having to apply a good amount of force, you got me worried.
Br,
Al
Old Sep 10, 2018 | 01:22 PM
CptWiggles's Avatar
CptWiggles
Yeah, with the amount of force I had to use to get the injectors and fuel rail off there's really no controlling how it goes you just kinda use a pry bar and try to pry in the right direction. Not sure what I would done had the o rings or plastic pieces actually fallen into the cylinders. I really don't see how to change the knock sensors without removing the fuel rails though. Good luck either way.
Old Sep 10, 2018 | 03:17 PM
bealljk's Avatar
bealljk
dont rely on luck ... stuff rags into or tape-off the intake manifold
Old Sep 11, 2018 | 11:55 AM
iideadeyeii's Avatar
iideadeyeii
Well, you'll never even see close to 300whp without FI
Old Sep 12, 2018 | 09:37 AM
CptWiggles's Avatar
CptWiggles
Ya think? not even by stroking it to 3.7l and cams...
I'm using 350whp as a generalized benchmark to ask a question about the ability of the stock injectors, not a dick measuring contest.
Old Sep 12, 2018 | 09:39 AM
CptWiggles's Avatar
CptWiggles
This is a good point, I don't know why I didn't do this. But you would have to stuff those rags really deep into the lower intake manifold in order to catch anything that comes off the injectors.
De La Money
Jun 25, 2011 01:21 PM
JETPILOT
Jan 8, 2006 07:15 AM
