Map Switching/ Cruise Control/ UPREV
I have a 6 speed base model 2008 350z (HRMT) and have added the CC (cruise control) switches along with the clutch cancel switch and brake switch to go with it. I know since it is a base model the cruise cluster light wont turn on. I got tuned with UPREV but cant switch maps or use launch control unfortunately. My tuner has made sure to use a rom from a z that has it from factory.
Things i have tried:
changing clock spring
removing and reseating the clutch and brake switch
Things i think might be affecting it:
I have a CEL (check engine light) from Camshaft Position Sensor "a" bank 2
ABS light is on. Codes for abs below
c1111 (pump motor)
c1104 (left front sensor 1)
c1140 (actuator rly)
Brake light is on and doesnt throw code up
Any help is much appreciated thanks!
c1111 (pump motor)
