Experience with replacement tires (Not Bridgestone)
Old Nov 29, 2004 | 04:01 PM
MELRUMMY's Avatar
MELRUMMY
Default Experience with replacement tires (Not Bridgestone)
I have over 42k on my 2003/Auto/Touring. Nissan replaced all tires at 18k and they are starting to get noisy. Roaring, particularly on smooth roads. Has anyone had a good experience with new non-Bridgestone tires. I will need new rubber in 10-15k if the noise doesn't drive me nuts.
Otherwise a phenomenal car !!!!
Old Nov 30, 2004 | 06:11 AM
Zenvy's Avatar
Zenvy
Default Re: Experience with replacement tires (Not Bridgestone)
most people will say do a search, but i'm bored right now. i see signs of feathering already after 2000 miles on my tires (look at sig)
however, i see signs of feathering on most cars out there...but probably not to the extent of what's seen on our cars.
Old Dec 1, 2004 | 05:22 AM
Q_350Z_USAF's Avatar
Q_350Z_USAF
Default A Multitude of choices...
If you stay stock I would say go with the same OEM tire that came with the car. However if you decide to upgrade, try Toyo's or Dunlop or Goodyear. Just a suggestion, but there a good bit of tires to choose from that are reasonably priced to the high end depending on the size you want and availability.
Old Dec 1, 2004 | 06:53 AM
westpak's Avatar
westpak
SFZCC
Well 18k on first set and 24k on second set I would say you are doing pretty dam good, I am at 25k and on my third set, so far RE40's and S03's feathered but Toyo T1's didn't but rears wore quickly
ablaine
Nov 29, 2016 10:13 AM
kyin
Oct 15, 2015 05:54 AM
Stevo Z
Oct 3, 2015 09:14 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
