help with fitment
Bolt Pattern: 5x114.3
Off Set: +45mm
i'm not staggering the rim size but i am staggering the tire size.
will this fit? easy yes or no .
Off Set: +45mm
Why would you want to tuck them more than they are already stock? That's going to look goofy....as far as will it work? Don't think anyone else has intentionally gone down that road. Good luck.
Keep searching other's posts with those size wheels...but I think you should be looking in the teens if you want the stance to look nice. I'm running 25+, but am running 9.5 and 10.5 wheels with 265 and 295 tires respectively. Go to tire tracks offset conversion chart and punch in my offsets and wheel sizes to get a similar stance with the 8.5 with wheels you are looking at...think it would be a good start. Our stock offsets are around 35+ depending on the model...the lower you go on offset, the further out the tire sits...but wheel width plays a factor...so if you are going 8.5 from the stock 8's, and went with a 35+ offset it would still sit a little different...get it? Do a search..lots of info for ya
Off Set: +45mm
Off Set: +45mm
Yes it will fit as long as you do not have the track model. But the off set is kinda high. Try to find somthing with a 35-40 off set.
