Ok tire experts... Here we go again 9.5 and 10.5 ??
I am sure this has been covered millions of times, I did do a search but wasn't really finding the answers I wanted. So here is my question.
I am getting 9.5 in the front and 10.5 Rear with a +28 offset in the front and +23 Offset in the rear
My question is what would be the correct tire size to run?
Im hearing a mixed of answers and also is their going to be rubbing involved. I would like to hear from those who are running this type of setups and your personal experience with them. I would like to get 255x35 in the front and 285x35 in the rear. Or would I have to sacrifice the tallness of my tire size for width do it wont rub? I don't want it to rub but I don't know if I like the "streched" look... Pictures would be awesome!
Thanks in Advance
Thanks in Advance
Here's what I was running when I had 20s:
Front Tires: Pirelli P-Zero Rosso 255/35/ZR 20
Front Wheels: Maido III GR5 9" 3 piece rim. (.26 offset)
Rear Tires: Pirelli P-Zero Rosso 285/30/ZR 20
Rear Wheels: Maido III GR5 10.5" 3 piece rim. (.29 offset)
Car was also lowered with Eibach Pro Springs and had very little rubbing (only extreme situations).
Welp, I usually check TireRack as they're on the ball most of the time.
For 18x9 / 10.5 on the track Z (2k4/Brembos) ..
18x9 +31 245/45-17 (they should mean 18/typo?)
18x10.5 +43 275/40-18
Those numbers are for the Comp-H's w/the optional 10.5 rears .. which I happen to have a set of
You'd be fine with what you suggest. I'm running 265 and 295 respectively on the same size wheels you plan to run with very similar offsets (25+ all the way around) No rubbing issues and I'm dropped.
COOL!!! Thanks guys, I did A LOT OF REASEARCH and I have narrowed it down to this...
It seems the 9.5 might be a little to much for the front, I have even heard of rubbing issues when you turn?
So Im going to stick with 8.5 in the front and 10.5 in the rear. Also Yokohama only makes a 245x35 tire so that kinda limits me too... As for the rear I will go with a 295x35 because it seems a lot of people have ran this setup and don't have issues.
Thanks again guys! Also anybody else recommends a good tire setup.. Its a ***** to find tires nowadays, i def still considering the 9.5 in the front... AHHH DECISIONS?
So Im going to stick with 8.5 in the front and 10.5 in the rear. Also Yokohama only makes a 245x35 tire so that kinda limits me too... As for the rear I will go with a 295x35 because it seems a lot of people have ran this setup and don't have issues. Thanks again guys! Also anybody else recommends a good tire setup.. Its a ***** to find tires nowadays, i def still considering the 9.5 in the front... AHHH DECISIONS?
Originally posted by Wicked4u2c
...I am getting 9.5 in the front and 10.5 Rear with a +28 offset in the front and +23 Offset in the rear...
...I would like to get 255x35 in the front and 285x35 in the rear...
Wicked - I'm on the same boat as you because I want to buy the following wheels:
-> 19x9.5 - 19x10.5 - Axis Hiros
but does your Z have TCS or VDC because with the 255x35 - 285x35 your stagger = +0.83 (which is incorrect according to Nissan)
Check out my post:
https://my350z.com/forum/showthread....hreadid=102527
Check out my post:
Check out my post:
On the same boat as you wicked.
Wonder who has had any rubbing issues with the 9.5 in front that would be kind enough to chime in?
Does Toyo T-1s make any rubbers between 275-35 and 295-35?
Good thread.
Good thread.
Originally posted by southern_info
So the final decision is i can run a 19x10.5 in the rear and a 19x9 in the front with no rubbering issues and no fender rolling?
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
