WHEEL / TIRE STAGGER on VDC cars (PICS included)
Old Jan 9, 2005 | 10:27 PM
Z BOY's Avatar
Z BOY
Originally posted by myz8a4re
one more thing to note to both dewuser & zboy is this: the relation of tire width to wheel width is going to be off front to rear. this is another reason most go with the 254/35 & 275/35 combo. try to look beyond height stagger at this point. the 255 on the 9.5 in rim will have an even amost bulkier look than the 275 on the 10.5" rim, wich will look a bit stretched. also with this tire width arrangement & the offsets you mentioned above you will have the rear looking much more sucked in than the front. this will make you wish you went with a less aggressive front offset.....the tire tread to sidewall will end more inside the fender with a 275 tire on a 10.5" wheel while the tread end on the 255 tire on the 9.5" rim will be much further outward exaggerating the rear being pulled in more than the front. look at it like this, the difference in width between the 2 tire sizes you are interested in is.300 of an inch. the difference in wheel width is 1.0", so you can see how the tire will fit differently on each rim......this would not be so bad if the front offset were a little less aggressive........its not a huge issue but if your in anyway as **** as i am about the way your car & wheels/tires look this will make you nuts, lol!
best of luck!
-justin
jeez, i'm buying 18x9f and 18x10r volk gt-n wheels, and i have no idea what the offsets should be. any thoughts? maybe the 255/275 idea isn't so great on this wheel size, afterall?
Old Jan 10, 2005 | 11:37 AM
Z BOY's Avatar
Z BOY
okay, i just found out the offsets available for this wheel. If i want to run 255/275 stagger with 18x9f and 18x10r, would the following offsets look good? Which would be best for my z? i do not plan to install a bbk anytime soon.
fronts: 22mm with 69mm lip
rear: 22mm with 81mm lip (also available in 24mm, 29mm offsets)
Old Jan 10, 2005 | 02:37 PM
myz8a4re's Avatar
myz8a4re
unfortunately the front wheel will be tucked in alot more than the rears with that setup. your looking at an even offset front to rear but 2 inches difference in wheel width. when you have a difference of 1" front to rear(width) the same offset works out perfect as far as eveness goes. honestly zboy, the 255 will be a tad bulky on an 8" rim. the 2mm lighter offset they offer in the rear wont make up for how less agressive the front will look......now im talking here as if you ARE as **** as i am about the tires fitting the wheels & where your wheels sit in your fender well. with those wheel sizes you are loking to buy i would say the best offsets would be around 22mm rear & 16mm front. if you run a 8.5" wheel up front then 22mm all around would look perfect. im not saying you cant run those offsets or that it would look terrible, just a tad more sucked in in the front. the 255/35 tire would make it look a little less tucked since there will be more meat in terms of tire width. mabey thats what your looking for....im a bit opinionated, hope i helped!
-justin
Old Jan 10, 2005 | 03:52 PM
Z BOY's Avatar
Z BOY
-justin
Justin, thank you so much for taking the time and effort to help me with this. I, too, am very **** about my baby (i go to bed at nite and wake up in the morning thinking about her), and i'm looking for the best combo of looks and performance. Besides, sucked-in cheeks only looks good on skinny runway models. When i'm done with my wheels, i wanna be able to say "my baby's got back AND front."
To clarify, i'm looking at 18x9"f (not 8") in front. Would this wheel width with the 22mm offset make the 255/40/18 tire fit and look ok up front?
I'll wait for your response to this question before i ask if 275/40/18 tires on 18x10r will look good and complementary in the back with a 22 offset in back.
Old Jan 10, 2005 | 04:27 PM
myz8a4re's Avatar
myz8a4re
zboy, im sorry, im completely had the wrong wheel size figured for your front. i thought for some reason you were going with 18x8 & 18x10, sorry about that....with the 1" width stagger between the wheels the 22mm front & rear offset will look great! very aggesssive looking & even with the fenders front to rear!! the 255 will look much better on a 9" rim than an 8" rim of course. but with that offset i cant guarentee you will not rub under hard cornering on the front inner fender. i know you would be fine with a 245/40 & 275/40 as im sure you know. the 255 is about .400" wider than the 245. it doesnt sound like much bit really shows up when it comes to tires...........as for the rear with 275/40, that tire will look great on a 10" wheel. i believe that tire/wheel/offset combo is the max w/o rubbing in the rear. will be very close front & rear but look agressive as heck! i run 19x8.5 & 19x9.5 with 245/35 & 275/35 tires. i have a 15mm front & 20mm rear. your front rim will sit about exactly where mine does wich is dead flush & your rear will sit a shade outward more than mine wich will be dead flush! i could have went 15mm front/rear to be dead flush but i feared rubbing the fenders in the rear. i wish i could tell you for sure that your tires wont rub on hard corners but i cant. it will be very close! if your willing to do a little fender rolling if needed your setup will be very hott! sorry i cant be of anymore help, i dont want to lead you to believe somthing that isnt true.......best of luck!
-justin
Old Jan 10, 2005 | 04:37 PM
myz8a4re's Avatar
myz8a4re
z boy, i snapped a few pics along time back before i lowered my z. sorry about the crappy shots, i used my cell ph camera...this will give you an idea of where my wheels sit in relation to the fender. your front will be in the exact location while your rears will barely sit out further than mine......
front:
Attached Thumbnails WHEEL / TIRE STAGGER on VDC cars (PICS included)-fr-sd.jpg
Old Jan 10, 2005 | 04:38 PM
myz8a4re's Avatar
myz8a4re
rear:
Attached Thumbnails WHEEL / TIRE STAGGER on VDC cars (PICS included)-rr-sd.jpg
Old Jan 10, 2005 | 04:41 PM
myz8a4re's Avatar
myz8a4re
you can also get an idea of how the 245's fit a 8.5" wheel & how the 275's fit a 9.5" wheel. the 255's will look bulkier than my 245's & the 275's would look a tad less bulky than what you see on mine. im pretty happy with the overall fitment with tires & offset though! hope the pics can help as well........
-justin
Old Jan 10, 2005 | 04:44 PM
Z BOY's Avatar
Z BOY
two words: suh weeet!!! Looks awesome, Justin.
Thanks again for all your helpful input. You are a true gentleman and scholar.
I'll post pix of my setup when it gets here in 1-3 mos from Japan.
Old Jan 10, 2005 | 04:55 PM
myz8a4re's Avatar
myz8a4re
np z boy! cant wait to see pix when you get your wheels!
-justin
JjL
East Canada
Jun 12, 2019 03:04 AM
SpartanZ32
Oct 22, 2015 09:36 AM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
416blueZ
Sep 25, 2015 10:00 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
