offset for 10.5?
Old Dec 22, 2004 | 04:58 PM
SooMighty's Avatar
SooMighty
Default offset for 10.5?
what offset do you need to get for 19x8.5 in fron and 19x10.5 in the rear for a G35C? I dont plan on lowering my car. And dont want to roll fenders. I dont want any rubbing or other problems that stock rims wouldnt give me. I just want to put on the rims and end it at that. Dont want to adjust anything. what offsets should I get? I know for the 8.5 and 9.5 it is a +21 +23.
Old Dec 22, 2004 | 05:03 PM
tylerdurden's Avatar
tylerdurden
+22 is generally the cut off for non-lowered cars. If you run 275 rubber you should be OK. You may want to keep it in the +30 range to avoid headaches.
Old Dec 22, 2004 | 05:54 PM
SooMighty's Avatar
SooMighty
I just want to know what offset I need for a 8.5 and 10.5 set up. I dont want to roll fenders and Im not lowering my car. dont want rubbing or none of that.
Old Dec 22, 2004 | 08:23 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
+30mm on the rear of my 18x10.5 with 295/35/18 rubber...
I am fully slammed...
30mm you dont NEED to roll your fender or cut them... you can even run 38mm no problem...
Old Dec 23, 2004 | 02:08 PM
tylerdurden
Find a wheel that you like and find out what offsets they offer. Different manufacturers usually have limited offsets available.
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
