Front Right Wheel Bearing? Problems anyone?
Old Dec 24, 2004 | 08:32 AM
Zenvy's Avatar
Zenvy
Default Front Right Wheel Bearing? Problems anyone?
Ok...i 've searched wheel bearing problems and they are in the rear and i've heard someone had front left wheel bearing problems due to headers or something like that.
I believe i have front right wheel bearing troubles...car makes humming noise from front right tire well at variable speeds and at variable driving times...also has begun to make brake squealing noises when making full left turns.
So what do you guys think?!
BTW...MERRY CHRISTMAS Everyone!!!
Old Dec 24, 2004 | 10:39 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Our car uses a sealer hub.bearing assembly. It is one unit, and nothing really to fix or replace. They rarely go bad in such a short period of time, unless they were subjected to a side impact/accident.
Usually, when they go bad, they will start to squeak, or they will vibrate at higher speeds.
Not sure what the hub assemblyi would have to do with the headers though.
Old Dec 24, 2004 | 04:49 PM
westpak's Avatar
westpak
SFZCC
If the bearing was bad you would hear a rythmic hum at higher speeds not so much at low speeds, like sharif said it is a single unit which also contains the sensors for the ABS....... stuff
I know because mine was bad after an accident.
bcoffee20
Nov 19, 2015 06:39 PM
CrowzRSA
Sep 21, 2015 04:00 PM
Beater350z
Sep 9, 2015 03:36 PM
