Question on LE37t fitting
Old Dec 27, 2004 | 10:45 AM
aznstyle29's Avatar
aznstyle29
Default Question on LE37t fitting
LE37t 19x9.5 +22 front
LE37t 19x10.5 +22 rear
so will this fit without modifying the fender?
i thought this would? but i was reading a lot of stuff on TE37's and this not being able to fit without fender shaving...
Ummmm also how do u get a really thick lip. is it the offset? or is it the width of the rim?
trying to get the rims to look like this one... what size are his/her rims
Old Dec 27, 2004 | 11:52 AM
Z Goddess's Avatar
Z Goddess
Default Re: Question on LE37t fitting
Is the vehicle lowered or at standard height? Do you have plans to lower, and if so to what extent?
Old Dec 27, 2004 | 01:28 PM
OgreDave's Avatar
OgreDave
That the mustang set on eBay?
I don't think you can get away w/doing +22 10.5 on rear .. ppl might say it fits fine if you don't lower .. but you will probably rub on decent bumps, decent turns, and trunk load ..
I could be wrong (no experience trying 10.5 +22) but I have 10.5 +43 rear .. per TireRack's recommendation.
Old Dec 27, 2004 | 01:37 PM
ttsupra94's Avatar
ttsupra94
I have a 10.5 +26 and i'm lowered.....no problems here
Old Dec 27, 2004 | 01:52 PM
LUCK's Avatar
LUCK
From what I've told, if you have 8.5 +22 on front, 9.5 +22 rear, it'll be fine.
If you have 10.5 +22 rear, YES, you need to roll your fender.
I ordered mine back in mid September and still haven't gotten the rims.
I was told about 3 weeks to get it but here is almost 3 months already.
LUCK
Old Dec 27, 2004 | 02:01 PM
ZZtopp's Avatar
ZZtopp
That's my car.....even with the 1/2" drop of S-techs, no need to
roll. If you drop it more than that, you might have to.
Old Dec 27, 2004 | 05:15 PM
Dragonstyle's Avatar
Dragonstyle
If you want a really thick or deep lip, it does depend on both your rim width and offset chosen...plus also kinda depends on your rim model.....
issyz
Jul 2, 2017 03:04 PM
