need a shop to lower my ride
Old Jan 11, 2005 | 08:18 PM
ch@mp's Avatar
ch@mp
Default need a shop to lower my ride
anyone know of any shops close to fullerton, like cerritos or OC area that offer real good prices to lower. Purchasing some vogtland springs... like under a 100.
Old Jan 11, 2005 | 10:10 PM
HipHopPro's Avatar
HipHopPro
F1 in North Hollywood, CA. I don't know where Fullerton is.
http://www.f1motorsports.com/services.html
Old Jan 11, 2005 | 11:11 PM
Jung918's Avatar
Jung918
fullerton is around the 5 and 91 area
Old Jan 12, 2005 | 05:08 AM
King Tut's Avatar
King Tut
Do it yourself or find another 350Z owner in your area that can help you with it. I know with all the people in CA that someone can help you out.
Old Jan 12, 2005 | 05:49 PM
ch@mp's Avatar
ch@mp
thx for the responses, found a shop and had them installed... the "paranoid" thing is when i drive, the front left side makes this "dunk dunk" noise. I called the guy back and he said, it's a pretty common thing. He said the springs need to settle into the grooves.. he also said that give it a couple of days and if it still makes that noise, then bring it back to the shop. anyone know what i'm talking about?
Old Jan 12, 2005 | 06:22 PM
Jung918's Avatar
Jung918
new springs need to be broke-in aka settled
go get an alighment after about a week or so
Old Jan 12, 2005 | 07:50 PM
protocav's Avatar
protocav
i have never heard a noise. there is definitely something wrong with the install. perhaps they forgot to tighten the end links?
Old Jan 12, 2005 | 08:09 PM
ch@mp's Avatar
ch@mp
DAMN'T! DAMN'T! the sounds like a deep creaking noise, but shorter of a length. i'll drive it around for a couple more days. i was thinking maybe the springs weren't fit correctly into the grooves or something. it only comes from the left hand front side... very annoying at 5-45 mph but on highways i can't seem to hear it. all i know is, that sound wasn't there before the install.
Old Jan 12, 2005 | 08:17 PM
ppw350Zunit's Avatar
ppw350Zunit
what shop did the install and how much was it?
Old Jan 12, 2005 | 08:19 PM
ch@mp's Avatar
ch@mp
it's called wheel and audio. located in buena park, right next to the kenwood outlet off the 5/ firestone. 160 w/ alignment. well more like he eyeballed it.
Old Jan 12, 2005 | 09:06 PM
ZZtopp's Avatar
ZZtopp
Eyeballed it??? An alignment? You're kidding, right?
Old Jan 12, 2005 | 09:32 PM
ch@mp's Avatar
ch@mp
ok that was a tasteless joke, sorry...
Old Jan 12, 2005 | 09:42 PM
ZZtopp's Avatar
ZZtopp
Oh I get it......the guy had only one eye, right?
Old Jan 13, 2005 | 08:11 AM
Bertg's Avatar
Bertg
'Dunk Dunk' noises? Did you go back to the shop to have them check it out? As for an alignment, I recommend West End Alignment in Gardena.
Old Jan 13, 2005 | 02:17 PM
ch@mp's Avatar
ch@mp
Bertg, literally it sounds like "DD-unk DD-unk" on local streets, more noticeable at low speeds.. some other people have mentioned that its probably because the springs haven't fit completely into the groove yet, all speculations and theories of course.... unfortuanately i've got work during odd hours so, i'm giving it till this saturday for it to "settle in" the paranoia has "settled" in tho
Old Jan 13, 2005 | 04:56 PM
nastyZ's Avatar
nastyZ
maybe the springs weren't placed properly..... not sitting on the tab properly???
Old Jan 13, 2005 | 06:30 PM
protocav's Avatar
protocav
perhaps they didn't tighten down the 17mm upper strut (perch) bolt enough, and there is not enough preload on the springs.
Old Jan 13, 2005 | 07:05 PM
ch@mp's Avatar
ch@mp
heres a little info on the springs i've installed on the Z. they are vogtland,
i think thats exactly what the it is. there's a groove where the bottom of the spring presses up against, and i'm thinking it's not completely touching, so everytime it bounces the spring hits the groove but not completely resting up against it.
might be it... i mean it (sound) comes only from the front left side...i'll take it back on saturday, if it persists....
damn't, protacav, i should've just taken it to you.. that way i get to meet another person on the forum in person... and check out your Z...
another bad decision making mistake in the ilfe of CH@MP
Old Jan 14, 2005 | 08:13 PM
PSR Performance's Avatar
PSR Performance
The spring will not make noise if it is not sit in the pocket ( it can just not the noise you are describing), the reason is that if the there is full load on the spring it can't move. It is most likely the upper strut nut that holds the shock shaft to the upper spring perch. If this is not seated correctly (and sometimes certain shafts are "keyed" have flats machined into them) the shaft can move up and down through the upper spring seat. It only has to move 1/16" to make a noticeable noise. In addition there may also be a missing washer / spacer.
Have the shop inspect the entire asembly completely, this will require them to remove the strut from the car.
If the problem persist, e-mail me at:
info@psrperformancegroup.com
Old Jan 14, 2005 | 11:22 PM
tractng's Avatar
tractng
PSR Performance,
I am thinking of lowering my car. What do you charge with alignment?
Tony
