Heim Jointed Drop Links
Old Jan 22, 2005 | 06:16 AM
uro279's Avatar
uro279
Default Heim Jointed Drop Links
What are they and what do they do?
Are they neccessary to replace when getting new sway bars? I ask this because Nismo has their new sways with links included, yet you could get the same sways without from 350evo.
thanks.
Old Jan 22, 2005 | 06:47 AM
ALong's Avatar
ALong
The end links are what connect the swaybar to the suspension of the car. The stock OEM end link is a fixed lenght, with no adjustment, and the end links have rubber bushings to help reduce ride harshness.
The Heim-jointed end-links have solid metal spherical bearings in place of the rubber bushings so that there is not play in the end-link, also they are adjustable length wise so that any pre-load can be taken out of the sway-bar.
Bottom line, if the car is just driven on the street, you are ok with the stock end-links, but is the car sees any track use, the heim-jointed end links make a difference
apex locator
Jul 23, 2021 02:27 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Tochigi_236
Sep 27, 2015 03:40 PM
