NISMO LMGT4 Tire Size Help
Old Mar 14, 2005 | 08:32 PM
jreiter's Avatar
jreiter
Originally Posted by lowrider
Sentry
You really don't want to mix different brands of performance tires. Might bo OK on a Civic with M&Ss. On a performance car with performance tires you want to stay with the same brand and model. Handling characteristics differ from brand to brand, and those differences will be exacerbated if the tires are mized. Look at the differences in tread design, and you'll see how different they are.
Lou
I would normally agree with you on this one. However, there are circumstances where mixing the front and back can actually be useful, *especially* on a high performance car. One great example is a friend of mine here in my town with a 350Z. (His name is "Sosa" here on the boards.) He's actually running Toyo RA-1's in the front (super sticky r-compound), and T1-S's in the rear. This completely eliminated the Z's notorious understeer. He's a track junkie, and he said it was the best handling mod he had done to date.
I guess the trick is to just know what you're getting in to. If you're careful about how you mix them and are aware of the handling differences between the tires and what they'll do the response of your car, then I say go for it. But you're right that you don't want to mix them *****-nilly without considering the consequences first. And definitely never mix the left and right sides!
Old Mar 15, 2005 | 05:27 AM
BobaFettm's Avatar
BobaFettm
Well I also researched a bit about the Kumho ECSTA MX and all the guys on my Autocrossing forum are raving about them also!!! Anyone had any experience with these on their 350z?
Old Mar 15, 2005 | 11:54 AM
sentry65's Avatar
sentry65
the burninator
one of the reasons i was going to mix the front 255 PS2's with rear 285 KDW2 was to help give more oversteer to the balance of the car in comparison to my 225 and 245 stock which are a closer with ratio to each other.
255 front and 285 rear will understeer more than 225 front and 245 rear. I know I can try messing with tire pressure and suspension settings too to help compensate. I don't think I can put my rear 350EVO sway bar on the stiffest setting (currently on middle) because the nismo exhaust probably won't let you because they're touching right now as is - won't be easy anyway from what I can tell.
I suppose I could try putting on a 265 KDW2 in front, but it'll just be heavier, will be slightly larger tire buldge which isn't as healthy, and the steering would be even more sluggish. You can't get 265/40/18's anyway. I really like PS2's and they don't have any good rear sizes for 18" that'll fit a 9.5" wheel and maintain the sidewall ratio between front and rear tires
I'm really not sure what "negative" thing will come from mixing tires unless you do some sort of crazy extreme, but i'm not really a tire expert either. How is it any different from choosing different tire sizes?
Old Mar 15, 2005 | 12:00 PM
kitkos's Avatar
kitkos
I have these wheels. See my signature for tires.
Old Mar 15, 2005 | 12:48 PM
BobaFettm's Avatar
BobaFettm
Yah I've decided to go with the F1's!!! They stacked up best against all the others... MINUS the ps2's
Old Mar 16, 2005 | 06:59 PM
jreiter's Avatar
jreiter
The only trick might be that you are mixing super sticky PS2's in the front with not-so-sticky KDWs in the back. Careful or you might get oversteer! But I'm sure it'll be fine. Like I said earlier, my friend put R-compounds in the front and regular tires in the rear, and it was perfect on stock suspension.
ablaine
Nov 29, 2016 10:13 AM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
