Need help with spacers
Old Apr 6, 2005 | 08:21 PM
sroks5's Avatar
sroks5
Default Need help with spacers
Need some help....I have 20x9 +31 and 20x10 +37. What size spacers should I get if I get 255/35 and 285/35 tires?
Old Apr 6, 2005 | 09:34 PM
StefanZ's Avatar
StefanZ
Well, if you assume that spacers come in only 5mm increments, you are sorta stuck. Assuming you don't want to roll your fenders, I'd do this:
1) front 5mm spacer (to +26mm); rear 15mm (to +22mm).
It isn't ideal, because I'd think that you'd like the front tire in about 3 more mm, so you could do a 10mm spacer in front, but I think you're best off spaced the way I described. GL.
Old Apr 7, 2005 | 06:40 AM
sroks5's Avatar
sroks5
oops...my mistake its a +37 in the front and +38 in the rear.
Old Apr 7, 2005 | 08:54 AM
StefanZ's Avatar
StefanZ
Then I'd go 15mm both front and rear.
Old Apr 7, 2005 | 09:15 AM
sroks5's Avatar
sroks5
thanks for you help
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
