Tire size for 19x9.5 wheels all around for 03 Z?
Old Apr 17, 2005 | 07:14 PM
JDMFairlady21's Avatar
JDMFairlady21
Default Tire size for 19x9.5 wheels all around for 03 Z?
i'm planning on putting on 19x9.5 et25 front and et15 rear wheels on my Z. question i have is- what tire size should i run on these? should i stagger as well? its more of my daily driver for summer so i'm not going for a track setup, i just want to put the proper tires on the wheels andd hopefully improve the performance of the car while upgrading the looks. any input would be much appreciated.
Old Apr 19, 2005 | 05:56 PM
JDMFairlady21
so no one got any idea or suggestion on what would be a good tire setup for my wheel setup moentioned above?
Old Apr 19, 2005 | 07:46 PM
Landbarger's Avatar
Landbarger
The SCC project Z ended up putting 9" up front because that's all they could fit, do you know your wheels and offsets will work?
Old Apr 19, 2005 | 08:49 PM
GY-Z's Avatar
GY-Z
265 or 275 tires depends on the brand is the most ideal for 9.5 width rims
going non-staggered tires setup will also improve your tire life.
you can rotate it front and rear, left to right with a symetric tire.
though you'd most likely has to roll ur fender for ur rear if ur planning to drop your car.
Old Apr 19, 2005 | 08:55 PM
JDMFairlady21
i'm pretty sure that 9.5 et 25 would clear on the front easy with a 245/35... most JDM tuners have used 9.5 for the front without widebody or fender mods... they ran 9.5 et 22 up front and 10.5 et 22 at rear and it clears. i was thinking of doing the conventional 245 front 275 rear combo, eventhough the rim size aren't staggered???
Old Apr 19, 2005 | 10:08 PM
GY-Z's Avatar
GY-Z
the tire will be stretched on 9.5 with 245, but its still doable.
and lots of JDM tuner did roll their rear fender with 10.5 22 rear.
at least i know Amuse do, and their running around -2 camber in the rear too.
burglapfd
Dec 6, 2020 01:04 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
kyin
Oct 15, 2015 05:54 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Depravity
Oct 1, 2015 04:49 PM
