Volk LE37T.. Hubcentric rings.
Old Apr 24, 2005 | 11:52 AM
Alex_Z's Avatar
Alex_Z
Default Volk LE37T.. Hubcentric rings.
How many hubcentric rings are needed??
I ordered a set of volks with tyres and only received 2 hubcentric rings, i was told there just for the fronts??
Thing is, i'm getting some major vibration / wobble over 60mph, like it's unbalanced. Haven't checked the tyre balance yet, as the tyres were already mounted and balanced before shipping.
Old Apr 24, 2005 | 12:32 PM
jlimquest's Avatar
jlimquest
I got 4 w/ mine for each wheel. That is probably what's causing your vibration. You can check ebay for some.
Old Apr 24, 2005 | 12:52 PM
Alex_Z's Avatar
Alex_Z
Thanks..
Anybody know what size hubcentric rings are needed??
Should really go back to the supplier and get them to send, but need some asap, car is undrivable...
Old Apr 24, 2005 | 12:59 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
They are the same ones for the maxima..if that helps
Old Apr 24, 2005 | 01:48 PM
havabooz's Avatar
havabooz
hub rings have 2 sizes...the one that fits to the wheel and the one that fits to teh car..our cars are 66.06mm ...shouldnt be hard to find out the other size by calling a vendor or something..hope that helps
hub rings should fix your problem especially if your wheels arnt bent
Old Apr 24, 2005 | 07:16 PM
ssc's Avatar
ssc
damn, i didnt get any rings with my LE's...are these things really necessary?...my wheels are not mounted on the car yet, btw
Old Apr 24, 2005 | 07:20 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
yes if you dont want what hes got....
Old Apr 24, 2005 | 07:26 PM
ssc's Avatar
ssc
damn, i hope my local wheel shop have these rings in stock....i am very disappointed that my vendor did not mention this to me
Old Apr 24, 2005 | 07:28 PM
jlimquest's Avatar
jlimquest
Yes, Volks normally supplies them w/ the wheels (below). It helps center the wheels & prevents wiggling.
Old Apr 24, 2005 | 08:05 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
most auto stores have them...auto zone, pep boys etc... they might not be listed under 350z but the maxima ones work I understand
Old Apr 24, 2005 | 11:01 PM
Alex_Z's Avatar
Alex_Z
I really need the outer size of the hubcentric ring (the size of the volk) so i can try and source some in the UK!!!
Anybody??
Old Apr 25, 2005 | 04:53 AM
King Tut's Avatar
King Tut
I really doubt that is what is causing the problem. More likely it is a poor wheel balance or untightened lug nuts. Did you make sure the wheels were torqued to spec?
Old Apr 25, 2005 | 05:08 AM
Alex_Z's Avatar
Alex_Z
Yer tried the lugs. The tyres were balanced before being shipped, haven't checked this yet though.
Old Apr 25, 2005 | 08:03 AM
havabooz's Avatar
havabooz
actually you would be surprised what hub rings can fix...if your wheels arent bent and the tires are balanced properly then hub rings are the likely answer
if you dont have any wobbling and you dont have any hub rings either then its not a problem...you can still have a good mount without rings, its just tougher
Stevo Z
Oct 3, 2015 09:14 PM
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
