Tire and Wheel selection sanity check
Old May 7, 2005 | 05:44 AM
ken350z's Avatar
ken350z
Default Tire and Wheel selection sanity check
Hi all,
I've been reading everything here and doing all the homework to select the correct tire/wheel replacements. Before I buy them I want to run it by youz gyz to make sure I'm not screwing it up.
I decided to stay with the 17" wheel size because I'm more interrested in performance than looks. I think the 17s look good anyway. Also, I live in Connecticut where we're considering the pothole for the state flower.
The only question is if I should go with slightly wider than stock tires. I went to the Miata tire size calulator and found that going to 275 in the rear causes too much speed error but 255 in the rear works about perfect.
Stock:
Front: 225/50/17
Rear: 235/50/17
Slightly wider:
Front: 245/45/17
Rear: 255/45/17
I plan on using Goodyear F1 GS-D3 tires.
Will I notice any handling difference?
Is this a good combo?
What is the stock offset?
How do I determine the correct offset for these?
Are $500 forged one piece wheels really better than the less expensive types? (non-track use)
Thanks
Ken
Old May 7, 2005 | 07:11 AM
Z'd Up's Avatar
Z'd Up
did you mean your sticking with the stock 17" or aftermarket?
Maybe this table will help... for 17" look at disk A for the offsets, for 18 and 19 look at disk B
http://www.rayswheels.co.jp/cgi-bin/...elName=57S_PRO
Be sure to post picks once you get those wheels/tire combo...
I'm in the market for new wheels - and deciding what to get is driving me crazy
Old May 7, 2005 | 10:35 AM
ken350z's Avatar
ken350z
I'll be going with new wheels and keep the stock wheels for snow tires.
Ken
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
