ssr sp1
Old May 11, 2005 | 07:48 AM
anubyss's Avatar
anubyss
Default ssr sp1
I am trying to order some rims and this is what I've found. SSR Professor 18"x8.5" with 35 offset for front and 18"x10.5" with 30 offset for the rear. As far as I can tell from reading the forum and searching both should fit. I didn't find any threads with the exact offsets but some were pretty close. By chace anyone have these specific offsets on a Track model?
Old May 11, 2005 | 08:49 AM
anotheraznguy's Avatar
anotheraznguy
Those are sunken...
Especially in the front.
I run a 9+18 and a 10 + 22 and both front and rear are tucked.
Old May 11, 2005 | 09:37 AM
anubyss's Avatar
anubyss
Sunken? Meaning they will be too tucked in? Someone has 18x10 with 30 offset and he was saying it was flush with the wheel well. I don't mind if they are tucked in a little bit, as long as it clears the Brembo brakes.
Old May 11, 2005 | 02:10 PM
anotheraznguy
that you will have to discuss w/ whoever you are purchasing them from.
sunk is tucked in my opinion.
also.. are you going to roll fenders stretch camber etc...
it all matters..
Old May 11, 2005 | 05:49 PM
anubyss's Avatar
anubyss
Roll fenders stretch camber etc? This is why I am asking for feedback from someone that has these rims. I am not going to roll the fenders and camber doesn't have too much bearing in this case (more dependent on suspension) and I have no idea what 'stretch' you are talking about. I am just asking feedback hopefully from someone that has these rims. Thanks.
Old May 15, 2005 | 07:35 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
they will fit just fine - the front will likely need a spacer to clear the Brembo unless its the low pad wheel (unlikely but possible) - which is just as well - a spacer up front will bring the wheel to the edge of the fender (I'd go with a 10mm one). Out back, a smaller spacer will give you the look you want - ideally a 5-6mm will give you a great look and no rubbing issues
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
sherm
Sep 10, 2015 11:02 PM
scan
Nov 19, 2003 08:55 AM
z461
Nov 7, 2002 11:10 PM
