Axis Hiros
Old Jun 12, 2005 | 06:08 PM
jjellyneck's Avatar
jjellyneck
Stunning. I think they look perfect.
Old Jun 12, 2005 | 06:16 PM
kangol99's Avatar
kangol99
What kind of hood is on your Z?????
Old Jun 13, 2005 | 01:54 AM
chazzg's Avatar
chazzg
Veliside V3 hood
Old Jun 15, 2005 | 03:40 AM
Chad68's Avatar
Chad68
[QUOTE=chazzg]No spacer needed, the +20/+25 is a great offset for the Z. +15/+20 Like on the Axis Milano Looks just as good if not better(but the Hiro's do not come in that offset). The only reason I did not get the 10.5 in the rear was Axis only offered it in a +35 offset, and that would be too tucked in for my taste.
I have the Eibach Springs on my Z,(so about one inch) but for some reason it looks a little lower than other Z with the Eibach that I have compared it to.
Ok I got a question. I admit I don't fully understand the whole offset thing and more specifically how the numbers (+15 +20 +33 etc...) relate to how far the wheel sets in or out. All of my hot rods till now have been mostly motorcycles lol.
Anyway....
Are you saying that the 10.5" Hiro's with the +35 offset, leave more room between the outer edge of the rim and the fender lip?
If so, roughly how much more room would there be in between the outer edge of the 10.5" rim and fender compaired to your 9.5" rear wheels, with your +25 spacing?
Would there be 10mm more space or 5mm more space?
Old Jun 15, 2005 | 08:16 PM
jeffie7's Avatar
jeffie7
The lower the # the farther the wheel sticks out.
The stock offset I think is 35? I'm not sure but I think it's in that area.
Stock offset.
with a 22 offset
IMO a RWD car with a crappy offset makes the car look like a pansey. =)
Old Jun 18, 2005 | 12:08 AM
Chad68's Avatar
Chad68
Originally Posted by fongster
You have any pics taken of the rear or any others you can put up
Old Jun 18, 2005 | 11:40 AM
tommygunz's Avatar
tommygunz
Great job Chazz! The car has a very "clean" look to it. Very nice!
Old Jun 25, 2005 | 12:24 AM
Chad68's Avatar
Chad68
Hey chazzg I'm curious, Where did you order your V3 hood from?
And do you have any rubbing issues with either the rear or front when you push the car hard?
Old Jul 18, 2005 | 09:41 AM
pvknight's Avatar
pvknight
A 10.5'' rim is wider by .5'' on each side. 1 inch = 25.4mm. So the 10.5's are 12.7mm wider on the outer edge than the 9.5'' rim. But, the 35mm offset is 10mm more tucked in than the 25mm offset. +12.7mm OUT - 10mm IN = the 10.5'' rears should still stick out 2.7mm or 1/10th of an inch more than the 9.5s.
> to the Hiro or Milano owners, any thoughts on possible cracking? I hear Axis quality could be questionable, and my Z is a 30k/yr daily driver...
> and hey Jeff, that +22 rear looks mean. Are you running Hiro's as well? What size and offsets?
Old Jul 18, 2005 | 06:56 PM
lascala26's Avatar
lascala26
The Hiros that cracked were the last batch cast from their old plant. Not that many out there that cracked, you just hear about it more b/c people will need to vent. Call Axis....they will set you straight. If you are one of those people who got one of those wheels...they'll replace it...no questions asked. Axis make good mid-range wheels. I'm very pleased.
Old Jul 18, 2005 | 09:23 PM
jeffie7's Avatar
jeffie7
rears if I remember right are .22 offset. fronts I can't remember.
More pictures here.
https://my350z.com/forum/media-share/129434-some-pics-of-my-03-redline.html
Old Jul 18, 2005 | 09:24 PM
jeffie7's Avatar
jeffie7
More pictures here.
https://my350z.com/forum/showthread.php?t=129434
P.S they are tuckin in the new picture becuase I just lowered the car and the camber wasnt corrected yet. I've yet to take new pictures after installing my camber kits.
Old Jul 18, 2005 | 09:28 PM
Nexx's Avatar
Nexx
Thinking about getting these. What color Hiros for PPW? Silver, Gunmetal or the Bronze?
Old Jul 18, 2005 | 09:46 PM
VeilsideZ33's Avatar
VeilsideZ33
hawt wheels~ good choice - anybody wanna buy my 9.5"s? i need to get 10.5"s!!!!! lol
Old Aug 26, 2005 | 06:33 PM
Chad68's Avatar
Chad68
Chazzg,
Can you please tell me where you bought your Hiro's from and if you had any problems with the vendor? Thank I appreciate it. Did you get a wheel tire package deal? Thanks! I sent you a PM too.
Chad
35reilly
Sep 28, 2015 07:42 AM
HXS
Jul 12, 2003 04:53 PM
JAG
Mar 30, 2003 10:30 AM
hk350
Mar 12, 2003 01:14 AM
Heat
Feb 12, 2003 04:41 PM
