Tech Info - Wheel & Tire Sizes
Old Dec 5, 2002 | 01:37 AM
veilside z's Avatar
veilside z
Default Tech Info - Wheel & Tire Sizes
This is a basic update on the factory fit sizes for those of you interested in swapping out your rims (rpm=revolutions per mile):
17"x7.5J +30 225/50WR17 = Standard 17" Front (rpm=780.0)
17"x8.0J +33 235/50WR17 = Standard 17" Rear (rpm=768.0)
18"x8.0J +30 225/45WR18 = Standard 18" Front (rpm=777.0)
18"x8.0J +30 245/45WR18 = Standard 18" Rear (rpm=756.0)
18"x8.0J +30 225/45WR18 = Rays 18" Front (rpm=777.0)
18"x8.5J +33 245/45WR18 = Rays 18" Rear (rpm=756.0)
Volks TE37 18" setup
18"x8.5J +22 245/40R18 = Volks 18" Front (rpm=784.0)
18"x9.5J +22 275/40R18 = Volks 18" Front (rpm=756.0)
Volks TE37 19" setup
19"x8.5J +22 245/35R19 = Volks 19" Front (rpm=783.0)
19"x9.5J +22 275/35R19 = Volks 19" Front (rpm=759.0)
Nismo GT4 18" setup
18"x8.5J +25 245/40R18 = Nismo 18" Front (rpm=784.0)
18"x9.5J +25 275/40R18 = Nismo 18" Front (rpm=756.0)
If anyone else has tech info relating to specific brands & ACTUAL setups please post.
Please no photoshops, or wishlists - this stuff needs to work on the vehicle - get my drift???
Old Dec 5, 2002 | 12:00 PM
zland's Avatar
zland
Sport Z Magazine
Default Does anyone know this?
You posted ...
1. 17"x8.0J +33 235/50WR17 = Standard 17" Rear (rpm=768.0). This is the wheels my Z will have since it is a model E.
You said the wheels from factory on the 18" are:
2. 18"x8.0J +30 245/45WR18 = Standard 18" Rear (rpm=756.0)
Does anyone know if Nissan calibrated the speedo the same for all models or if the speedo is different on base & E models vs 18" models?
What i am trying to achieve is putting 18" after market wheels on my Z and yet have the speedo be accurate. Too bad the speedo is not programable as you change wheels/tires.
Is it easy to have the speedo recalibraded or is it too expensive?
Old Dec 5, 2002 | 12:28 PM
veilside z's Avatar
veilside z
Fluctuations in the rolling radius are an everyday occurence (even with pressure monitors).
All speedos are innacurate by some degree - a speedo that reads true at 30mph will not be true at 70mph & vice versa.
As long as you are there or there abouts everything will be fine.
I assume that the speedo calibration is common for all 350z's - if swapping out aim for somewhere near original, but don't be too much of a stickler for the exact match
F = 775.0 to 784.0
R = 754.0 to 768.0
Old Dec 5, 2002 | 01:12 PM
Russ's Avatar
Russ
It's been posted elsewhere before but check out this site to compare tire sizes:
http://www.miata.net/garage/tirecalc.html
or you can try out this spreadsheet (but you don't get the visual of the relative tire sizes)
File Type: zip
Old Dec 5, 2002 | 03:36 PM
Mr B's Avatar
Mr B
Am I correct to assume the speed sensors are mounted in the front wheels? So if you were thinking of getting slightly smaller tires in the back for shorter gearing, your speedo won't be affected at all as long as the front tires are within the range, right?
Old Dec 5, 2002 | 10:18 PM
ksj's Avatar
ksj
Can we add offset to the information? The Nismo LM-GT4's are +25 in front and +30 in the rear.
This should be a good thread if it can keep on-subject and become the basis of a portion of a tire & wheel FAQ...
Old Dec 5, 2002 | 11:05 PM
veilside z's Avatar
veilside z
Just to confirm - offsets are shown after the wheel size (the + figure). I will post an update including some new info after this post.
Nismo set up for LM4 wheels is +25 Front & Rear according to their website http://www.nismo.co.jp/index.html & the Z33 parts list
Old Dec 5, 2002 | 11:06 PM
veilside z's Avatar
veilside z
Default Updated Information
18"x8.0J +30 225/45WR18 = Rays 18" Front (rpm=777.0) 8.1kg
18"x8.5J +33 245/45WR18 = Rays 18" Rear (rpm=756.0) 8.3kg
18"x9.5J +22 275/40R18 = Volks 18" Rear (rpm=756.0)
19"x9.5J +22 275/35R19 = Volks 19" Rear (rpm=759.0)
Nismo GT4 18" setup
18"x8.5J +25 245/40R18 = Nismo 18" Front (rpm=784.0) 8.2kg
18"x9.5J +25 275/40R18 = Nismo 18" Rear (rpm=756.0) 8.6kg
All wheels are 5 hole with 114.3mm P.C.D.
If swapping out aim for somewhere near original, but don't be too much of a stickler for the exact match
F = 775.0 to 784.0
R = 754.0 to 768.0
Old Dec 6, 2002 | 08:16 AM
infinite z's Avatar
infinite z
That's really good info. I just wanted to point out something that I just learned, because I'm putting new tires on my stock perf rims. The front rims are actually 7.5", not 8". The Rays wheels are the only ones with 8" front rims. Just fyi.
Old Dec 6, 2002 | 11:13 AM
mcclaskz's Avatar
mcclaskz
Sorry infinite, you are incorrect. For 6MT Performance and 6MT Touring, the wheels are 18x 8.0 all the way around. It was old information where we had 7.5s up front. That is why some guys are putting 245/40 tires up front.
Old Dec 6, 2002 | 11:28 AM
infinite z's Avatar
infinite z
Well that's cool, I know I'm confused as hell as to which size is up front. The specs on nissannews.com say it's 7.5", but the manual doesn't list a 7.5" wheel. Oh well, I went with the 235/40 up front, I'm sure it will still look good.
Old Dec 6, 2002 | 11:53 AM
Boomer's Avatar
Boomer
The front tires should always be smaller than or the same size in the rear. Remember, the stock setup on the Z is 225/50/17s front and 235/50/17s on the back.
Stock setup for the 18s is 225/45/18 front and 245/45/18 on the rear. Your 235/40/18s should be fine on the front w/245/40?/18s on the rear if that is what you are changing to. The biggest tires always go on the back for the Z.
Old Dec 6, 2002 | 12:29 PM
infinite z's Avatar
infinite z
Oops forgot to give the size on the rear. Yeah actually I'm going 255/40 on the rear, to maintain the same size ratio with the front.
Old Dec 6, 2002 | 03:27 PM
Boomer's Avatar
Boomer
Default TECH.....
Should be fine, then. I hope you enjoy them.
Old Dec 6, 2002 | 05:43 PM
ksj's Avatar
ksj
Sorry - I missed it when I looked the first time. Thanks!
Old Dec 7, 2002 | 08:56 PM
Aloharacing's Avatar
Aloharacing
Default Re: Updated Information
If the diameter of the wheel remains the same, shouldn't the profile of these be 45 instead of 40's?
Could someone explain?
thanks.
Old Dec 8, 2002 | 12:47 AM
veilside z's Avatar
veilside z
This is the setup recommended by Rays (Volks).
Basically if the cross-section of the tire increases (225 to 245) the second figure will decrease as this is a percentile figure relating to the sidewall dimension (45% to 40%).
This keeps things there or there abouts, but does increase the contact width.
Thanx for spotting the error on the standard 18" setup - I will post corrected info after this post
Old Dec 8, 2002 | 12:49 AM
veilside z's Avatar
veilside z
Default Updated Information - 2
18"x7.5J +30 225/45WR18 = Standard 18" Front (rpm=777.0)
Nismo GT4 18" setup
F = 775.0 to 784.0
R = 754.0 to 768.0
I will periodically update (correct!) the info shown here so check for the latest version of this post later on in the thread… Thanx
Old Dec 9, 2002 | 06:13 PM
flynnibus's Avatar
flynnibus
Z Flier
Why don't you go back and edit your original post instead of making an entire new one? That way you lessen the chance of someone picking up incorrect info.
Old Dec 10, 2002 | 10:53 AM
veilside z's Avatar
veilside z
Nice idea but the edit limit is 90 minutes after posting...
