Tech Info - Wheel & Tire Sizes
Old Dec 10, 2002 | 11:13 AM
TheOne's Avatar
TheOne
what will happen if you got the volks 18x18.5 up front and the 19x9.5? will it produce a positive or negative result?
Old Dec 10, 2002 | 11:00 PM
veilside z's Avatar
veilside z
Using two different diameter wheels, 18" on the front & 19" on the rear, would not have any adverse effect on the whole setup - provided that you make sure the overall diameter (including tire)remains within the ballpark figures quoted.
With regards your "Positive or negative result" question though, personally I think this would look pretty odd. Keep all your rims to the same diameter just for the aesthetic.
- There's being different & there's being just plain damn strange...
Old Dec 12, 2002 | 11:37 AM
Luke@tirerack's Avatar
Luke@tirerack
Default Re: Tech Info - Wheel & Tire Sizes
Originally posted by veilside z
This is a basic update on the factory fit sizes for those of you interested in swapping out your rims (rpm=revolutions per mile):
17"x7.5J +30 225/50WR17 = Standard 17" Front (rpm=780.0)
17"x8.0J +33 235/50WR17 = Standard 17" Rear (rpm=768.0)
18"x8.0J +30 225/45WR18 = Standard 18" Front (rpm=777.0)
18"x8.0J +30 245/45WR18 = Standard 18" Rear (rpm=756.0)
18"x8.0J +30 225/45WR18 = Rays 18" Front (rpm=777.0)
18"x8.5J +33 245/45WR18 = Rays 18" Rear (rpm=756.0)
Volks TE37 18" setup
18"x8.5J +22 245/40R18 = Volks 18" Front (rpm=784.0)
18"x9.5J +22 275/40R18 = Volks 18" Front (rpm=756.0)
Volks TE37 19" setup
19"x8.5J +22 245/35R19 = Volks 19" Front (rpm=783.0)
19"x9.5J +22 275/35R19 = Volks 19" Front (rpm=759.0)
Nismo GT4 18" setup
18"x8.5J +25 245/40R18 = Nismo 18" Front (rpm=784.0)
18"x9.5J +25 275/40R18 = Nismo 18" Front (rpm=756.0)
If anyone else has tech info relating to specific brands & ACTUAL setups please post.
Please no photoshops, or wishlists - this stuff needs to work on the vehicle - get my drift???
and it is wrong ... it is the wheel dimensions for a Skyline GTR
Old Dec 12, 2002 | 12:30 PM
veilside z's Avatar
veilside z
Cheers Luke - Thanks for the constructive criticism!!
I don't get why you feel the info is incorrect? There were a couple of minor initial errors, which I have corrected through this thread, but the info posted is for the 350Z.
Check out the Nismo site http://www.nismo.co.jp/ , Rays site http://www.rayswheels.co.jp/ & a few of the Nissan sites.
Old Dec 12, 2002 | 12:38 PM
Luke@tirerack
Default Re: Re: Re: Tech Info - Wheel & Tire Sizes
Originally posted by VQracer
Since it is wrong could you post the correct info.
Thanks,
Victor
correct info ....
Front sizes that will work
18X8 ET38
18X8 ET35
18X8.5 ET37
18X8.5 ET33
19X8 ET35
19X8.5 ET33
19X8.5 ET37
19X9 ET29
Rear sizes that will work
18X9 ET38
18X9 ET35
18X9.5 ET38
18X10 ET40
19X10 ET41
Old Dec 12, 2002 | 12:48 PM
Luke@tirerack
Default Re: Re: Re: Re: Re: Tech Info - Wheel & Tire Sizes
Those aren't the factory sizes, which is what is trying to be posted here.
sorry ...I didn't realize 19" Volk are OE
and I edited the previous post
Old Dec 12, 2002 | 12:49 PM
veilside z's Avatar
veilside z
Default Updated Information - 3
18"x7.5J +30 225/45WR18 = Standard 18" Front (rpm=777.0)
18"x8.0J +30 225/45WR18 = Rays 18" Front (rpm=777.0) 8.1kg
18"x8.5J +33 245/45WR18 = Rays 18" Rear (rpm=756.0) 8.3kg
18"x9.5J +22 275/40R18 = Volks 18" Rear (rpm=756.0)
19"x9.5J +22 275/35R19 = Volks 19" Rear (rpm=759.0)
Nismo GT4 18" setup
18"x8.5J +25 245/40R18 = Nismo 18" Front (rpm=784.0) 8.2kg
18"x9.5J +25 275/40R18 = Nismo 18" Rear (rpm=756.0) 8.6kg
SSR GT3 19" setup
19"x8.5J +37 245/35R19 = SSR 19" Front (rpm=783.0)
19"x10.0J +41 275/35R19 = SSR 19" Rear (rpm=759.0)
BBS LM 18" setup
18"x9.0J +25 245/40R18 = BBS Type 194 18" Front (rpm=784.0) 8.2kg
18"x10.0J +25 275/40R18 = BBS Type 195 18" Rear (rpm=756.0) 8.6kg
BBS LM 19" setup
19"x9.0J +18 245/35R19 = BBS Type 196 19" Front (rpm=783.0)
19"x10.0J +22 275/35R19 = BBS Type 197 19" Rear (rpm=759.0)
All wheels are 5 hole with 114.3mm P.C.D.
Fluctuations in the rolling radius are an everyday occurence (even with pressure monitors).
All speedos are innacurate by some degree - a speedo that reads true at 30mph will not be true at 70mph & vice versa.
As long as you are there or there abouts everything will be fine.
If swapping out aim for somewhere near original, but don't be too much of a stickler for the exact match
F = 775.0 to 784.0
R = 754.0 to 768.0
I will periodically update (correct!) the info shown here so check for the latest version of this post later on in the thread… Thanx
Old Dec 12, 2002 | 12:54 PM
Luke@tirerack
Default Re: Updated Information - 3
SSR GT3 19" setup
F = 775.0 to 784.0
R = 754.0 to 768.0
edited out all of the Skyline fitments ... hope you don't mind
veilside z's Avatar
veilside z
Will do!
Ignore the pm
Old Dec 12, 2002 | 12:59 PM
McDan's Avatar
McDan
Default Re: Re: Updated Information - 3
So are you saying that the NISMO LM GT-4's will not correctly fit the 350Z???
Old Dec 12, 2002 | 01:11 PM
Luke@tirerack
while you can physically bolt the Skyline wheels to the 350 it is not the correct offset and will move the wheel further out and change the scrub radius angle of the suspension geometry causing abnormal handling. also there will be a decrease the slip angle the car is able to achieve creating additional understeer and less responsiveness to steering input
I read somewhere ... "you can put a windshield wiper on a billy goats *** but why would you ????"
You can put wheels designed for a Skyline on a 350 but, why would you ????
Old Dec 12, 2002 | 01:31 PM
McDan's Avatar
McDan
But I think most people would agree that they WANT to move the face of the wheel out a little bit to make it look more flush with the fender wells than the stock spec. Those Nismo wheels (rears)w/ +30 offset , would only push the wheel face out 8/10 of an inch (If I calculated it correctly). Not much...
Old Dec 12, 2002 | 01:32 PM
veilside z's Avatar
veilside z
Luke - Have you spoken to Nismo & Rays about that?
They are pretty certain the LM4's & the TE37's have been released for the Z. Check their sites (please)
Old Dec 12, 2002 | 01:42 PM
Luke@tirerack
didn't need to speak with them ... .saw the wheels at SEMA
can you put them on .... sure ... is it right ...NO ....
Old Dec 12, 2002 | 02:02 PM
veilside z's Avatar
veilside z
Sorry Luke, nothing personal.
You have your opinion (& I can not deprive you of that) but I am afraid that I will go with the "experts" at Nissan Motorsport & Rays on this matter.
Post pics & full details of any installs you do on the 350Z, then people can compare your installs to Nismo's... Let the people decide!
Old Dec 13, 2002 | 07:32 AM
papo470's Avatar
papo470
Smile Re: Re: Re: Re: Updated Information - 3
They will fit.
from NISMO website
18 X 8.5, 114.3 X 5, +25 Front
18 X 9.5, 114.3 X 5, +30 Rear
hi VQ racer, i saw these wheels that you are talking about in the NISMO website and the list the offset at +25, for both the front and the rear.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
