? What offset r u running?
It's hard to believe that the stock wheels are +30mm offset. But I've seen TE-37s on a 350Z before, and they looked pretty deep. I want some BBS wheels. I thought +5mm would be okay. What offset do you guys run?
Originally Posted by disturbed2483
+20 all the way around.
btw i think +5 would make your rims stick out quite a bit. i believe most people want to stay around +18 to +25 to make the flush.
Oh yeah, what about rim width? I got one guy here saying 9 in the front and 10 in the rear....
the width of your wheel and tire play a big role in choosing offsets
the stock 18" rims might be 30mm offset, but they're only 8 inches wide
A rear 295mm tire on a 10.5 inch rim with 43 offset would be practically the same flushness against the body work as a 9.5 rim with 275mm tires and a 30mm offset...
Originally Posted by Nforce1
Can someone explain offsets to me... I dont understand what they are. I know it has to do with how wheels sit, but.. what else?
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Performance Nissan
Performance Nissan
it depends on the width of the wheel...
if you run a 8" wide wheel in the rim.. and +0 offset will look flush with the fender...
actually...
10.5" wide rim in the rear with +30mm will line up the same with the fender as a 8.0" wide rim in the rear with +0mm
actually...
Originally Posted by ActionJackson
That makes it flush with the fender, but what if you wanted the wheels tucked in a bit? Then would +25-26 offset be good?
10.5" @ +29 295/35/19
5/8" drop with front wheels tucked and rear wheels tucked between 1/8-1/4"
This may help too...
https://my350z.com/forum/wheels-and-tires/86159-f_a_t_t_e_s_t-tires-on-a-19-rim.html
Zquicksilver
ps Click on my sig if you want to see what it looks like...
Alberto, Sweet wheels!!!! I see you got them from Evolution. I am not familiar with them. How was the service? Did you shop around before buying from them?
Finally, can I get some contact info for them? I'm shopping for Volks right now and based on your comments above, Evolution just might be the right place to get them from.
Then I've got to make a decision between the Volks and the Axis Reverbs (pic attached). I hear some folks have had issues with their Axis Hiros (cracking) and I'm pretty sure Volk makes a better wheel, although I bet they are more expensive than Axis.
Thanks!
Thanks!
