which tires would you recommend?
KUMHO ECSTA ASX
245/40/18 - front
275/40/18 - rear
OR...
BF Goodrich g-Force Sport
245/40/18 - front
275/35/18 - rear
I'm alittle unsure of the tiresize that should be used. the sidewall heigh is a percentage of the width, so if I keep the sidewall at 40, the sidewall height will be different on the kumho's. Where as the BFG's will be 40% of 245, and 35% of 275 (more of an equal sidewall).
I've never run a staggered set up before, so i'm not sure on tires. Which ones would you guys run? Cost is the same (save about 5 bucks for the set..)
Matt
245/40/18 - front
275/40/18 - rear
OR...
245/40/18 - front
275/35/18 - rear
Matt
