Random Question On Tire Size
Old Jul 28, 2005 | 05:54 PM
M3This's Avatar
M3This
Default Random Question On Tire Size
Ok I saw a artical with the Top Sec 350z (reg kit not wide body) running 245/35/19 Front and 275/30/19 Rear .... why run a 35 profile on the fronts and a 30 on the rear? .... they are also not the only ones doing that I have seen it a few times on tunners cars.
Right now on my racing harts im running 245/35/19 Front and 275/35/19 Rear ... so why drop the rear to a 30? Is it for looks? or due to lowering?
Any one have any ideas????
Old Jul 28, 2005 | 06:01 PM
baileyrx's Avatar
baileyrx
this will keep the sidewall height about the same
ie: 35% of 245mm = 85.7mm
ie: 30% of 275mm = 82.5mm (35% of 275mm = 96.2mm)-much wider sidewall
Old Jul 28, 2005 | 06:04 PM
M3This's Avatar
M3This
Thats what I thought but looking at my wheels that the rear tires look like the side walls where bigger ... I just thought I was trippin ...
Any benifit to handling ???
Old Jul 28, 2005 | 06:08 PM
baileyrx's Avatar
baileyrx
the "thinner" the side wall, the less tires flex you'll see when you take corners.
more sidewall, the more the tires "float" around on the rims
also more likely to feel every little crack in the road since there's less cushin between you & the road
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
Paul.
Oct 16, 2015 07:34 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
