Will my 17" IS300 rims 43mm offset fit?
Old Aug 1, 2005 | 06:47 AM
jysz's Avatar
jysz
Default Will my 17" IS300 rims 43mm offset fit?
Quick question, will my 17" Lexus IS300 rims (~43mm offset), wrapped in Michelin Alpines fit my 05 ZR? Can i get spacers to push them out a bit? I would simply slap them on to test it out if I had my car back from my 6/27/05 accident (woman cut me off hit me head on....woo hoo 11k damage + labor)
Thanks!
Old Apr 13, 2006 | 05:54 PM
Torched Z's Avatar
Torched Z
Anyone know if this will work or not??
Old Apr 13, 2006 | 07:59 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
I highly doubt that a wheel with a +43 offset will look flush to the side fender. Even with spacers, I think that they would still look awkward on the Z. How wide are the tires?
Old Apr 13, 2006 | 08:04 PM
sq40's Avatar
sq40
If you have brembo's you might run in to a rubbing problem. At +43 Offset you are running 13mm (Half Inch Roughly) further in the fenders on the front ant 10mm (almost a half inch) further in on the back. You should be able to notice the difference quite a bit. I would get a set of 20 or 25mm Spacer if you must run the wheels, just beware of the cost of those spacers will be in the $230+ range.
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
