Which tire size do you prefer, 17" or 18" ?
Old Aug 14, 2005 | 01:55 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
eh, its easy to adjust, but you will have to align every time...
you can drive daily with 0 camber in the rear, you will have better tire wear for daily driving, (that is unless you are like me and take every corner as hard as possible)...
Old Aug 14, 2005 | 05:47 PM
mrtomcat's Avatar
mrtomcat
that sounds very interesting.
I'm probably going get that done when I'm visiting you guys for my next tune up in about a month.
How much will that run me?
Old Sep 20, 2005 | 03:24 PM
ZinFla's Avatar
ZinFla
old thread i know but wondering if someone could answer my question, would a 245/40 and 275/40 setup fit on the stock 17s. i like 17s so im having em made gloss black and would like to throw some meaty tires on them so if anyone could tell me what the widest i could go is. especially jason since you have experience with the 17 inch wheel tire combo. thanks
Old Sep 20, 2005 | 07:41 PM
Jason@Performance
Performance Nissan
on the stock wheels those tire sizes would boulge out... cornering will be sacrificed and feel wabbly...
i wouldnt recomend more then 255 on the rear and 235 up front... even that is pushign it on the stock wheels IMHO...
Old Sep 23, 2005 | 11:58 PM
overboostedtoy's Avatar
overboostedtoy
go w/17s, lighter wheels = more efficient drive tran (release more ponies). you feel the difference if you remove 10 lbs from the drive tran. wont feel anything if remove 10 lbs from gross weight of the vehicle.
Old Sep 24, 2005 | 01:22 AM
I’ve been driving with 17-inch tires for about 32,000 miles: dry street, wet street, open road course (legal), drag racing, a little street racing. Overall, I’m content with the performance of 17-inch tires.
Old Sep 24, 2005 | 05:04 AM
Z BOY's Avatar
Z BOY
imo, 17s are dwarfed by the z's huge wheel wells.
Old Sep 24, 2005 | 08:31 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I would love to stay with 17s and go wider but I cant find tire sizes that don't reduce the overall tire diameter. In the end, out of convenience and tire choice and what I think is proper sidewall fit, I will probably end up compromising on 18s.
Chris
Old Sep 24, 2005 | 09:08 AM
ZinFla's Avatar
ZinFla
you can go slightly smaller then stock diameter. your going to be off by about 2-4 miles an hour with most profiles from when i checked bout goin 245/40 and 275/40 it was like 4 miles an hour or so so it wasnt bad.
Old Sep 24, 2005 | 01:15 PM
HyperSprite
Mad Scientist
It's not the speedo, although with my stocks it reads higher than reality (reads 85 at a real 81) so that would get even worse. I just don't like the look of the lower profile tire on a 17. In short, I want the same sidewall hight with wider tires so it fills the fenders the same way as stock. The smaller sidewall makes the fender opening look too big, even if the car is lowered, imo.
Chris
Old Sep 24, 2005 | 01:40 PM
ZinFla's Avatar
ZinFla
i guess but my thing is if you drop the sidewall height it looks less like suv tires. and you can drop it enough so that there isnt to much gap. eventually ill be going with the setup i mentioned and dropping the car over an inch. ive seen it done and it doesnt look like there is too much gap.
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
