285/35/19 fit on a 9.5?
Guys,
Just want to know if the tire would fit nicely on a 9.5 (+24 offset) with the hotchkiss springs?
Do I need to roll a fender?
Btw, I currently have 275/30 and like to fill the gap a little more. Some dude is selling a new set on the forum.
Thanks,
Tony
Thanks,
Tony
Originally Posted by tractng
Guys,
Thanks,
Tony
Thanks,
Tony
From Tire Rack under wheel specs There's no 285/35/19 Dunlop or S03
------------------DUNLOP--------MICHELIN PS/2----------BF GOODRICH S03
Tire Size--------285/30 ZR19------285/35 ZR19-------------285/30 ZR19
Max Load-----------1477 lbs.---------1709 lbs.----------------1477 lbs.
Inflation Psi------------51 psi------------51 psi----------------51 psi
Tread depth-----------10/32"------------0/32"----------------10/32"
Tire weight------------28 lbs.-----------28 lbs.----------------31 lbs.
Rim Width Range-----------NA----------9.5-11"----------------10-11"
Meas. rim width-----------10"---------------10"----------------10"
Sect. width-------------11.1"-------------11.4"----------------11.4"
Tread width---------------NA---------------NA----------------10.5"
Overall Diameter---------25.9"-------------26.9"----------------25.7"
Revs per mile--------------NA---------------774----------------811
Tread wear---------------280---------------220----------------220
Price--------------------$268--------------$388---------------$304
According to some other comparisons
The BF goodrich KDW's dont look bad
Excellent Traction
300 Tread wear rating
Its supposedly louder than all other tires
Its roughly 50 bucks cheaper than S0'3's and 100 than Michelin's
Has Good ride comfort
Excellent Traction
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
