Need help unbolting the front upper A arm.
Old Aug 13, 2005 | 10:06 PM
Omar350z's Avatar
Omar350z
Default Need help unbolting the front upper A arm.
Hi guys
I have a 2003 350z and I am currently in the middle of installing the Tein Flex Coilovers. I have followed the instruction in this web site
http://www.350zforum.com/tech/NISMOS...uspension.aspx
but I ran into a problem into the front suspension. The problem is when i tried to remove the nut on the upper link (A arme) the whole thing just keep turning and i turn the nut
Note: see picture number 24 on the linke above and please guys tell me what kind of tools i need to open that nut.
Thanks
Old Aug 13, 2005 | 10:23 PM
MrGraphics's Avatar
MrGraphics
You have to remove the pin. Bend the part that wraps around the threads, and make it straight, you can then pull it out. Make sure you replace the pin when you're done! (preferably with a new pin).
Obadabot
Jun 18, 2023 11:31 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
