Tire pressure Q
Old Aug 20, 2005 | 08:21 AM
The Brickyard Rat's Avatar
The Brickyard Rat
Default Tire pressure Q
Okay, Nissan recommended 35 psi on the oem tires.
I just put on Toyo T1 Rs in the SAME sizes as the oem tires.
But Toyo's have "50 psi" max on fronts & "44 psi" on rears.
What tire pressure should I run?
Old Aug 20, 2005 | 09:33 AM
Biochem7's Avatar
Biochem7
Regular
you do no want to run the maximum pressure the tire can handle. Run the 35 psi that Nissan recommends.
Old Aug 20, 2005 | 11:49 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Old Aug 20, 2005 | 02:32 PM
autois4pussies's Avatar
autois4pussies
I run 36 front and 35 rear even though my tires are way bigger than stock. I run 36 to help fight the front tire wear by getting a little less contact on the sides of the front.
Old Aug 20, 2005 | 03:24 PM
ssc's Avatar
ssc
i run 37-38 all around on my toyo's
Old Aug 20, 2005 | 08:07 PM
The Brickyard Rat
Thanks for the help, guys. I thought 35 psi +/- was the right answer.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
