Stagger set-ups
Old Sep 23, 2005 | 07:15 PM
Takhteh's Avatar
Takhteh
Default Stagger set-ups
So I have stock 17 wheels- 17x7.5 front, 17x8 rear. Tire specs, respectively, are 225/50/17, 235/50/17. Will these alternate set-ups work w/the stocks w/o any problem?- 225/45/17, 235/45/17? 225/55/17, 235/55/17? N whats the difference?
Old Sep 23, 2005 | 10:12 PM
overboostedtoy's Avatar
overboostedtoy
Those alternates will not post problems in terms of factory chasis balance. The only thing being different is the tire aspect ratio and responsiveness. the tire side walls on the first set will be shorter, the 2nd set taller; which might result in tires turning more or less revolutions per minute. Your cockpit mph might read faster or slower than the actual speed. The tolerance for aspect ratio is w/in +-5% of the manufacture spec w/o affecting your mph cockpit reading. Shorter ratio more responsive and vice versa. I would go w/ 235/45/17 all around. reason being Z tends to understeer. this set up will minize that plowing and the tire aspect ratio falls in the short front and taller rear, a good compromise in terms of responsiveness.
Old Sep 23, 2005 | 11:04 PM
Badmonkey's Avatar
Badmonkey
Do you have VDC? If you do you need to keep a certain amount of stagger. The rear tires must be about 1/2" larger in diameter, otherwise VDC may act up.
Old Jan 18, 2006 | 10:06 AM
sq40's Avatar
sq40
Does TCS Act up also?
Old Jan 18, 2006 | 02:21 PM
Click here for more than you ever wanted to know about wheels and tires for the 350Z
http://www.350zmotoring.com/modules....ex&name=Wheels
Old Jan 18, 2006 | 03:49 PM
350Zteve's Avatar
350Zteve
My advice would be not to spend any month on the 17s. Keep your eyes open in the classified section and buy some used track model wheels and tires. There are some great deals in there from time to time.
Old Jan 24, 2006 | 08:12 AM
Question
Was the chart that I posted helpful in selecting the correct wheel and tire sizes?
bcoffee20
Nov 19, 2015 06:39 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
KJ-350
May 16, 2003 09:09 PM
